Opinions on engine noise?
Old Jun 8, 2011 | 12:50 PM
yaro's350z's Avatar
yaro's350z
Default Opinions on engine noise?
Here is the scenario.
2007 350z, 71,xxx miles
When the car is in idle the engine noise is normal, nothing out of the ordinary.
When the car is revved up past 2K RPM, from the front of the engine you can hear a scratching/ slight knocking noise (as if the chain is loose inside and is hitting the inner wall of the cover). The higher the RPM the louder the noise.
Has anyone else ever experienced this?
Can anyone give any input on what might be causing this noise?
Thanks in advance!
Old Jun 8, 2011 | 02:11 PM
bmccann101's Avatar
bmccann101
that aint gona be enuff for anyone to go on man.. describe more... cmon you can do it.. get to typin.
Old Jun 8, 2011 | 02:52 PM
Arvin89's Avatar
Arvin89
More details.
Does it happen at a stand still? while driving? Both?
have you tried having someone rev it while you have the hood up so you can get a better idea?
Old Jun 8, 2011 | 03:14 PM
0jiggy0's Avatar
0jiggy0
at least provide a vid if it happens free revving
Old Jun 8, 2011 | 09:03 PM
winchman's Avatar
winchman
Does having the AC on make any difference? Sometimes the clutch on the compressor will make a little noise when it's not engaged.
Could also be the idler pulley, if it has one.
Old Jun 9, 2011 | 03:30 AM
kramykram's Avatar
kramykram
check your oil as our cars have a oil pressure tensioner on the timing chain. could just be low on oil.
Old Jun 9, 2011 | 04:48 AM
pce60's Avatar
pce60
+1 this is what it sounds like but this would prob happen at idle too.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
