People with 15K Mi Plus, POST
Old Jan 7, 2004 | 09:05 AM
Thaddeus's Avatar
Thaddeus
Default Re: People with 15K Mi Plus with NO Feather, POST
Originally posted by jeffa55
I started the post earlier of people with 5K plus, but if you have 15K plus on your car with no signs of feathering, please post here!! If there is anyone out there with 15K plus and no feather, I have to believe the problem must be fixable (as some cars don't have the problem).
Had the alingment and tire 'rotate' done at 8500 miles. Noise not only continued but became worse. Nissan NA sent 4 engineers to look at, drive and discuss. This occured at 16400 miles. Alignment checked and all OK. Given two new front tires, but because it is now winter I imediately put on the winter tires. One way or other I should know if the alingment will 'fix' or not.
Incedently, the NNA engineer said the reason they came to look at my vehicle was because the noise continued to become worse and this was very unusual.
When I loked at the original tires, I noticed not only the feathering we are so familiar with but also a patern occuring over 4 lugs on the inner tread band. The leading two lugs were high (and feathered) the next two were cupped (and feathered).
The engineers also said the feathering patern is simply the wear patern of an agresively set up suspension and tires having a 140 wear rating. He also stated this is typical of the 350 Z.
Good luck to all and happy new year.
Drive Well
May 30, 2017 03:28 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
