Replacing my master/slave cylinder
Old Jun 29, 2011 | 12:33 PM
Kyle R's Avatar
Kyle R
Default Replacing my master/slave cylinder
Lately, I have noticed that when engaging my cluth, the first 1/4th of the clutch is completely useless. Also, the clutch will not fully pop back up when it is disengaged. I would say 80 percent of the time, the cluth performs normally. I had the car checked out and was told I needed a new master slave cylinder. The total with labor is $550. When I repetitively pump the clutch, the problem goes away and the clutch stays strong. Any advice on whether I should replace the master slave cylinder or just deal with it? I'm sure this has happened to others. By the way, the car is a 2006 base 350z with 45000 miles.
Old Jun 29, 2011 | 05:33 PM
Wu-Watt's Avatar
Wu-Watt
-Motul
-Master/Slave
-Stainless steel clutch line
-Bleed the hell out of it
-Clutch
Old Jun 29, 2011 | 07:23 PM
Kyle R's Avatar
Kyle R
Originally Posted by Wu-Watt
-Motul
-Master/Slave
-Clutch
Ill try the Motul next week and then ill take a look into the stainless steel clutch line. Thanks!
Old Jul 1, 2011 | 05:57 AM
Wu-Watt's Avatar
Wu-Watt
^The clutch line is inexpensive so I recommend you do that when the fluid is flushed.
Old Jul 6, 2011 | 03:37 PM
drivessidewayz's Avatar
drivessidewayz
If you searched, you'd have found quite a bit of information on this subject. It's a common issue for the master cylinder to have crap built up inside it and it simply needs cleaned out. I'm actually about to do mine tomorrow; I may write up a DIY if I don't find one for it before then.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
