when to replace stock battery
Old Jun 29, 2011 | 06:08 PM
codek's Avatar
codek
Default when to replace stock battery
I have 70k miles on my car. And battery shows 14 volts but am not sure if battery needs to be replaced. I had to jumpstart my car twice from listening to the radio with my system for an hour or so. Any recs on a good battery?8
Old Jun 29, 2011 | 07:08 PM
mvp2765's Avatar
mvp2765
i just replaced my original stock battery last year and my car is an 04.. I don't know too much about batteries, but I have a yellow top in both my Z and my DD and i have yet to have any issues
Old Jun 29, 2011 | 07:56 PM
4 years is about right. The battery will fail in the winter when you try to start a cold motor.
Old Jun 29, 2011 | 08:14 PM
BlkdOutZ's Avatar
BlkdOutZ
14 volts is fine, The battery is still good. Sitting in your car with the radio on kills any battery quick because it is not getting a charge from the alternator...
Old Jun 30, 2011 | 06:18 AM
JMS71585's Avatar
JMS71585
I replaced my OEM battery with a Bosch battery about a year and a half ago. It came with a 3 year warranty. No problem since installing it. My Z is an 04.
Old Jun 30, 2011 | 11:15 AM
Snowhiteboiler's Avatar
Snowhiteboiler
My car was showing 14 volts but had almost zero amps... get a tester and check it or more than likely, pull it out and take it to a battery shop and they can check it, before you replace it. You need amps to turn the car over.
Old Jun 30, 2011 | 11:27 AM
redline06's Avatar
redline06
youre getting 14V when the car is running because its being charged but look at the voltage while cranking, if it falls to 10V its done
Old Jun 30, 2011 | 11:35 AM
JCITY's Avatar
JCITY
Have an 03...bought new.Battery lasted 4 years.
Old Jul 4, 2011 | 03:30 AM
Never mind. I thought this was important. Important enough to say “thanks” or simply reply.
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
Tochigi_236
Sep 27, 2015 03:40 PM
