HELP ASAP- Clutch pedal has no resistance
Old Jul 4, 2011 | 04:36 PM
Wikiwiki's Avatar
Wikiwiki
Default HELP ASAP- Clutch pedal has no resistance
Pulled into my friends driveway- sitting with the car on- went to get push down on the clutch and it just goes all the way back- and sticks there- no resistance at all
when you pull it out and springs back into place
you can start the car- put it into gear when it is off
clutch has never slipped, any ideas as it was working and then now it doesn't.
Old Jul 4, 2011 | 04:50 PM
Wikiwiki's Avatar
Wikiwiki
I am guessing it is one of the cylinders- but I dont know why it would just die all of the sudden- from what I have read they usually show signs of wear and tear
I am going to top the fluids off tomorrow- see if that does anything
if it is one of the cylinders does anyone have a link to the service manuals or a how to guide on replacing them?
Old Jul 4, 2011 | 04:55 PM
terrasmak's Avatar
Start with a bleed , most likely the master is bad. The master likes to stick, read up on some threads about it. Very simple to replace or rebuild.
Old Jul 4, 2011 | 05:28 PM
Wikiwiki's Avatar
Wikiwiki
thats what I am thinking. I have done it with a friend on an s4- its a major PITA searching on new forums haha- hope its just the fluid needs topping off- in the mean time Im going to get drunk and launch some fireworks now
Old Jul 5, 2011 | 02:17 PM
bmccann101's Avatar
bmccann101
Winner of best noob thread and thread reply.
Be very proud.
This is a very sought after prize given out it appears only 5-6 years between good noob posts/replies.
I know its lolz.. but im serious. thats frikn funny.
Old Jul 5, 2011 | 07:44 PM
Wikiwiki's Avatar
Wikiwiki
haha I try- good news is all of my fingers are still here after last night
anywho went to go see if any pressure had built up in the clutch this morning- nothing- still kick right to the floor and stays there
So unless anyone has any other ideas I am going to bleed it- see if that works- if not definitely do the master-
questions are should I do the slave at the same time- and any step by steps or anything to that nature
Old Jul 6, 2011 | 09:58 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
It's a pretty straight forward job. Get up under the dash and unbolt the plunger from the pedal, then go into the engine bay and unbolt the lines. Have a container ready to catch the brake fluid and try not to let it drip anywhere. Brake fluid destroys paint. Once you've got the lines unbolted and the fluids stopped dripping... Unplug any wiring and unbolt it from the firewall.
That's a very rough how-to, since I've never done a master cylinder on a Z, but that should be close enough to get you on the right track.
Personally, I would do the slave while you're at it but that's just me. Don't forget to bleed the system when you're done.
Good luck.
Old Jul 6, 2011 | 10:38 AM
terrasmak's Avatar
Unless you can get the master cylinder piston to return, you will not be able to bleed it. If you have fluid in the reservoir now, its definatly the piston sticking. If it is dry, you may be able to bleed it.
It is only 2 bolts, one line and a clip that holds it to the pedal. Simple to remove, then one c clip once its removed to disassambe and clean. Cleaning it should fix it, if you want to rebuild it, its only $15 for replacement parts directly from Nissan.
Old Jul 6, 2011 | 11:15 AM
Wikiwiki's Avatar
Wikiwiki
I am going to clean it and if that doesnt work I'll be ordering the refurb kit tonight- it seems pretty straightforward- only question I have s bleeding this similar to the brakes- and if so where is the bleed screw at.
Also can I run a braided line from the reservoir to the cylinder just for ***** and giggles?
Old Jul 6, 2011 | 11:31 AM
bmccann101's Avatar
bmccann101
id say if youre gna take it apart, why NOT rebuild it? Buy it at a local Nissan parts counter.
The bleed valve is on the slave cyl.
And since its all going dry, yes, replace w a SS line.. possibly a new slave if youre hi mileage.
I just replaced my entire set up, but Terrsmak is big into just cleaning his.. I prefer to keep my plunger dirty.. thats what they make penecillin for . Ha. jk.
Old Jul 7, 2011 | 10:41 AM
Wikiwiki's Avatar
Wikiwiki
alright- took it apart- every spring and seal is in perfect order- just a shitload of gunk on it- reassembled it and then ran to the store to get some fluid- started to rain so bleeding it will have to wait until tomorrow-
Old Jul 8, 2011 | 09:29 AM
Vivid Racing
Vivid Racing
That gunk came from somewhere... Do you have any aftermarket lines? I've heard some low quality lines will cause issues with gunk.
Old Jul 8, 2011 | 09:57 AM
midz350's Avatar
midz350
I'm 99.9% sure that you have a 07+ 350z and the problem is the clutch slave cylinder (CSC).
Read here for the recall:
https://my350z.com/forum/vq35hr/3281...-cylinder.html
Read here for the after market CSC:
https://my350z.com/forum/drivetrain/...?highlight=csc
Read here for my solution to eliminate the problem for ever:
https://my350z.com/forum/vq35hr/4495...?highlight=csc
Old Jul 8, 2011 | 10:29 AM
terrasmak's Avatar
Its an orange/brown sediment, probably from the fluid breaking down. My 05 that had this problem is bone stock.
OP... as far is braided line. The one between the master and slave i would replace, the one between the master and reservior i wouldnt both with.
Old Jul 8, 2011 | 08:39 PM
Wikiwiki's Avatar
Wikiwiki
The car is an 03
-there was an orange gunk all around the piston and the seals
went to go put the fluid in and bleed it today- started to drizzle- my phone goes off saying flash flood warning and not even 5 seconds later it starts pouring- rained 4 inches in 1.5 hours
needless to say havent gotten around to fixing it yet
also just a question- there is no fluid in it right now- the clutch still kicks all the way to the floor when pushed on- that should be to no fluid correct- I sure as hell hope so as this has been a major pain
still better than my last car- went through a transmission- 2 turbos, clutch and flywheel on that *****- b5 S4
Old Jul 11, 2011 | 11:32 AM
Vivid Racing
Vivid Racing
Correct. Without fluid, the pedal will go to the floor. Don't push the pedal more than neccesary. Dry seal + dry reservoir = torn seal. Gotta have something to lube it up, dude!
Old Jul 13, 2011 | 12:30 AM
Panda_stunter's Avatar
Panda_stunter
What year is ur Z?
In my personal experience, it's the clutch slave cylinder. My car is in the shop right now for this. And this is the third time it has happened. Also, I noticed that the csc fails when it's hot out, I live in Vegas so desert heat doesn't really help.
If u have an 07, this is the most likely culprit. But if u have a different year, start with the clutch slave cylinder. Then go down the line, next up is the clutch master cylinder, then seals, then look for leaks.
Edit: just read ur car is an 03. Still, start at looking at the csc. The symptoms u just said resembles a failed csc. I know, it sucks driving then that clutch sticks to the bottom.
Old Jul 13, 2011 | 07:49 AM
kramykram's Avatar
kramykram
Just put fluid in it and pull the pedal back up by hand, being an 03 the stock slave line probably gave out. As it seems to happen a lot.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
