$4.5k Repair surely not, help needed
Old Jul 6, 2011 | 09:41 AM
stevedowny's Avatar
stevedowny
Default $4.5k Repair surely not, help needed
I purchased a 2007 350z and the check engine light came on soon after I bought it, the dealer kindly read the codes and replaced the two sensors which were flagged however now the engine light has come again and the dealer advised me to have the local nissan garage look at it and pin point the problem
The main dealer quoted the following:
exh/ v tim cont. B-1 and B-2 upon inspection found reading out of range causing sensor reaction
replace exhaust timing sprocket B-1 and B-2 with H-covers $4547.72
The dealer I purchased the car from is more then happy to help me out but they asked if maybe I could find out exactly what this problem might be???
Old Jul 6, 2011 | 09:51 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Based on what you've posted, the dealer should have no issue figuring out exactly what the issue is. The exhaust timing sprockets are the issue.
Old Jul 6, 2011 | 09:55 AM
Junkster's Avatar
Junkster
im sure almost 90% of that is going to labor...thats a decently sized job lol
Old Jul 6, 2011 | 10:00 AM
redline06's Avatar
redline06
wtf 4.5k! fukkk all that noise, how many miles r on it
Old Jul 6, 2011 | 10:17 AM
Blu_Blur's Avatar
Blu_Blur
Is there a warantee that may cover it. How long have you had the car and how much mileage until brought in to the dealership?
Old Jul 6, 2011 | 11:03 AM
drivessidewayz's Avatar
drivessidewayz
Not enough info. They will do the work for you, but want you to figure out what's wrong? Something doesn't add up.
Old Jul 6, 2011 | 11:18 AM
856_reilly's Avatar
856_reilly
Yea not enough info. From what your saying and that's wht needs there raping you!!!!!.
Old Jul 6, 2011 | 11:44 AM
lgear080's Avatar
lgear080
exhaust timing sprocket? sounds made up.
did you pay for any other work?
they don't call them stealerships for nothing.
Old Jul 6, 2011 | 01:11 PM
Junkster's Avatar
Junkster
How is that made up?
Sounds like a cam sprocket to me...
Old Jul 6, 2011 | 01:37 PM
djamps's Avatar
djamps
Hopefully it's just the cam sensors not the whole sprocket... the sensor replacement is a DIY job. Def. get a 2nd opinion from a trusted VQ shop.
Old Jul 6, 2011 | 04:32 PM
lgear080's Avatar
lgear080
my point is that i have never personally heard of this part failing.
Old Jul 6, 2011 | 05:07 PM
kacz07's Avatar
kacz07
What codes were you getting?
Old Jul 6, 2011 | 05:09 PM
stevedowny's Avatar
stevedowny
The dealership who i purchased the vehicle from are a privately owned used car dealership, I cant fault them as they are helping me all the way
I will post up which sensors they replaced tomorrow, although the car does not rev past about 3k if that may help anyone come up with an idea of whats wrong
Old Jul 6, 2011 | 09:04 PM
kramykram's Avatar
kramykram
if it makes you feel better ill sell you a hr engine for 2500 with 30k miles on it
Old Jul 6, 2011 | 09:15 PM
Itzcashew's Avatar
Itzcashew
The blinker fluid is low.
But in all seriousness did they give you the OBD code?
Old Jul 11, 2011 | 09:43 AM
stevedowny's Avatar
stevedowny
I just spoke to the stealership and the guy was telling me cam sprockets and the exhaust sprocket are causing the ignition timing to be off, which in turn is not allowing the car to rev past 3k rpms
Never heard of such rubbish in my life, how can the sprockets on the end of the cams go bad?
Old Jul 11, 2011 | 09:58 AM
pcressey's Avatar
pcressey
Perhaps one or more of the tensioners failed, or became loose, causing the chain to not be snug, in turn wearing out the sprockets. I just had my engine rebuilt and my sprockets showed signs of some wearing. My best guess on that one.
Old Jul 11, 2011 | 02:16 PM
Zing!'s Avatar
Zing!
MAF?
Old Jul 11, 2011 | 02:35 PM
97supratt's Avatar
97supratt
The sprockets may go bad but 4500 to repair? That's more than what it costs for another engine or rebuilding yours.
Old Jul 12, 2011 | 02:39 PM
e46330i's Avatar
e46330i
It would cost less for you to buy a low mileage engine and have them put it in.
