Hard pedal until car warms up
Old Jul 20, 2011 | 05:02 PM
JackMcNASTY's Avatar
JackMcNASTY
Default Hard pedal until car warms up
So for the last week I have been having an issue where the brake pedal is super hard as if the brake booster is toast but when the car warms up the pedal goes back to normal. It seems to be fine from then on until the car completely cools down again.
Anybody have any ideas? I would think if it was a bad booster the temp of the car wouldn't make a difference.
Old Jul 20, 2011 | 06:59 PM
winchman's Avatar
winchman
I'd take a look at the check valve in the vacuum line between the engine and brake booster. If it sticks in the closed position, the booster won't see the vacuum, and that makes the pedal hard.
Old Jul 21, 2011 | 03:27 AM
JackMcNASTY
The valve is between the engine and the booster? I thought I read that it was between the engine and the battery compartment.
Old Jul 21, 2011 | 08:35 AM
winchman's Avatar
winchman
The check valve is built into the hose that's closest to the booster assembly. You can see in the diagram here marked 47474:
http://www.courtesyparts.com/350z-pa...5_806_813.html
Old Jul 21, 2011 | 03:19 PM
JackMcNASTY
That probably explains alot. I ran a fuel system cleaner through that tube and it probably gummed something up.
Old Jul 21, 2011 | 07:03 PM
MikeBit's Avatar
MikeBit
Don't touch any of that garbage....... fuel injector cleaners blah blah. It's all a bunch of bs products that do more harm than good to your car.
Old Jul 21, 2011 | 11:24 PM
winchman's Avatar
winchman
At less than $20 for a replacement hose assembly, it's a cheap lesson.
Old Jul 23, 2011 | 10:05 AM
JackMcNASTY
This fuel system cleaning is not bs. I have been doing them on my car since 1996 with always good results. Measurable results.
Anyways. I found the valve and it is in the hose by the battery compartment. I sprayed it with some cleaner and it works fine now.
05UltraYellow
Sep 24, 2015 05:41 AM
