wierd noise when shifting into 2nd
Old Aug 10, 2011 | 05:29 PM
ksuberk54's Avatar
ksuberk54
Default wierd noise when shifting into 2nd
I have a 2006 350z 6spd and when I shift into 2nd when I'm driving it sounds like metal is hitting metal and its a really loud sound. It didnt do this when I was sitting still seeing if it still made the noise, only when I'm shiting. I just had the car in the shop for belts and a o2 sensor being reaplaced and they didn't say anything about anything else being wrong. Is there something I'm doing wrong or not pushing it hard or light enough into 2nd? thanks in advance.
Old Aug 10, 2011 | 06:32 PM
CTZ860's Avatar
CTZ860
Is it a grinding noise or more of a clunk?
Have you found anything on the net yet?
Old Aug 10, 2011 | 06:34 PM
The 350Z “finicky” transmission is an 8 year old subject. Dozens of threads devoted to this subject.
Old Aug 10, 2011 | 06:57 PM
ksuberk54's Avatar
ksuberk54
nothing. I know the 2003-05 models had problems but this isn't a griding noise, I've driven a 2003 and this isn't it, it's more of like the shifter trying to get into gear and it sounds like its hitting something but it's only when I drive not when I just sit there. It does it like 85% of the time which leads me to believe I'm doing something wrong and it only does it into 2nd gear, idk.
Old Aug 10, 2011 | 07:05 PM
temoku's Avatar
temoku
my 2006 and my 2008 did the same thing
Old Aug 10, 2011 | 07:13 PM
ksuberk54's Avatar
ksuberk54
do u think installing a short shifter would fix this problem?
Old Aug 10, 2011 | 07:49 PM
redman333's Avatar
redman333
Lol no
Old Aug 10, 2011 | 07:51 PM
redman333's Avatar
redman333
The problem with the first transmissions is the synchos. Which if there is a problem with them they will only shownwhile moving. You'll need a new trans or a rebuild with new or upgraded synchros. You can also upgrade the whole trans which is what I did and get the cd009 trans and I am extremely happy I did that.
Old Aug 11, 2011 | 07:38 AM
tvan's Avatar
tvan
My 2004 Roadster has the same problem. I find it helps to grag out 1st a little longer (3000-3500 RPMS) then it slides into second perfectly (atleast mine does) guess they just like to be driven fast?
Old Aug 11, 2011 | 07:57 AM
F34RL355's Avatar
F34RL355
same problem on my 08, i consider this a problem and am gonna go try and get it replaced, that and my gear is starting to grind going 3rd to 6th
Old Aug 11, 2011 | 09:58 AM
Z33Garage's Avatar
Z33Garage
OP, search "throwout bearing" for sauce
Old Aug 12, 2011 | 01:34 PM
ksuberk54's Avatar
ksuberk54
I did this today and it worked perfectly. definitely wierd though haha. Also, another thing thats wierd is that when it does make that noise it only does from 1st to 2nd. When I downshift or go from neutral to 2nd when I'm coming off the highway it never makes this noise. Oh well, I won't worry about it since I'll be shifting at 3500 now.
Old Oct 12, 2011 | 03:25 PM
F34RL355's Avatar
F34RL355
well my tranny got replaced, gear grind is gone, but clunk noise is still there
Old Aug 7, 2014 | 07:22 PM
bb17's Avatar
bb17
Necrobump I know, but how can you tell what transmission you have? My 2007 350Z Nismo is developing a transmission grind through all gears despite being driven gently. Currently at 48,000 miles. Wonder what transmission model I have.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
