low rpm rattle!! PLEASE HELP!!!
Old Aug 10, 2011 | 05:51 PM
socal z's Avatar
socal z
Default low rpm rattle!! PLEASE HELP!!!
Hey guys, I just got my Z a few weeks ago, its a 03 with 84k, and I have a annoying clangy metallic rattle when i take off in 1st, the rattle only occurs thru 500-1500rpms then it disappears, theres no rattling while im idling whether the clutch is in or out. It only occurs while moving slow (louder when going uphill) at low rpms
The dealer said it was a throw out bearing but that didnt seem right since there was no rattle while idling, anyone have any ideas? thanks.
Old Aug 10, 2011 | 05:54 PM
TheFarmer's Avatar
TheFarmer
Pinging/detonation?
Old Aug 10, 2011 | 06:13 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Modifications? Test pipes?
Old Aug 10, 2011 | 06:43 PM
socal z's Avatar
socal z
not a pinging sound, and no mods or test pipes
Old Aug 10, 2011 | 07:18 PM
carlos305's Avatar
carlos305
Aluminum flywheel?
Old Aug 10, 2011 | 07:20 PM
carlos305's Avatar
carlos305
Oh wait u said it does it which clutch in or out if it was the flywheel it should go away with clutch in. Not sure then...
Old Aug 11, 2011 | 07:37 AM
bmccann101's Avatar
bmccann101
post youtube cell ph video.
Old Aug 11, 2011 | 05:07 PM
drivessidewayz's Avatar
drivessidewayz
Out of curiosity: is it strictly in first, or is first the only gear you're below 1.5k in?
Old Aug 11, 2011 | 07:29 PM
socal z's Avatar
socal z
It can be heard in any gear if the rpms r low enough (below 2500)
Old Aug 12, 2011 | 08:49 AM
xxnismoxx's Avatar
xxnismoxx
i had the same problem, it turned out the person had an exhaust on the car before i bought it and the bolts on the exhaust weren't fasten tightly, so check that out. it could be a threaded bolt that is leaving a cap between the exhaust and the y pipe.
Old Aug 12, 2011 | 09:18 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
I'm also betting on the exhaust. The reason it doesn't do it in idle is because the engine isn't under load. Does it make the noise if you're in 1st gear with the clutch in, not moving? If so, it's probably the exhaust.
Put the car on a lift and check all the bolts for tightness. Also see if you can spot any places that show wear from rubbing on the pipes or chassis.
Old Aug 12, 2011 | 09:14 PM
socal z's Avatar
socal z
thanks guys,
i already checked the exhaust briefly but imma do a more thorough check this weekend. i can kinda hear it with it in 1st (not moving).
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
