Noise Underneath Car???
Old Aug 17, 2011 | 07:01 AM
chicagokid's Avatar
chicagokid
Default Noise Underneath Car???
I couldn't find anything in search for this??
At start up and start to drive away at about 5-10 miles per hour there is this vibrating sound and then goes away after 20+ miles per hour. Its under the car, not under the hood. I'm not sure if it's the heat shield or ???
Any ideas what it might be?? Everything is stock, car is 3 years old and about 29K miles.
Old Aug 17, 2011 | 07:07 AM
jerseystyle's Avatar
jerseystyle
Clutch clatter?
Old Aug 17, 2011 | 07:15 AM
chicagokid's Avatar
chicagokid
I have auto trans. Would that make a difference?
Old Aug 17, 2011 | 07:24 AM
350Zappa's Avatar
350Zappa
Short buzzing noise. Lasts just a second?
Old Aug 17, 2011 | 07:51 AM
jerseystyle
Yep. Search the tech forum.
Old Aug 17, 2011 | 08:04 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
It's probably your exhaust rubbing on something. Put the car on a lift, and look for any spots with shiny metal, or areas that should be dirty but aren't. If that doesn't work, then turn the car on and see if you can get a friend to replicate the sound while you're under the car.
Old Aug 17, 2011 | 02:43 PM
amr_electron's Avatar
amr_electron
It's your ABS & it's normal.
Old Aug 17, 2011 | 03:28 PM
angelo350z's Avatar
angelo350z
How neat is your car? It might ba a heat shield.
Old Aug 17, 2011 | 03:30 PM
Waiz's Avatar
Waiz
+1
It could be a number of things but since you're bone stock it will be easier to find.
Old Aug 17, 2011 | 04:07 PM
Vivid Racing
Vivid Racing
ABS should not be causing vibrations at all times during idle and below 20 MPH. In fact, the only time you should notice ABS is when it kicks in, or when it pressurizes; which only happens very momentarily when the car is started.
Old Aug 17, 2011 | 05:30 PM
DavesZ#3's Avatar
DavesZ#3
That's my guess. Since OP didn't really say how long it lasted, it's hard to say for sure. Mine normally does it about 30 seconds after startup while I'm first driving away so the timing would be right - going 15-20 mph. Loud vibration.
Old Aug 18, 2011 | 10:24 AM
JERZ350's Avatar
JERZ350
My ABS isnt really a vibration, its more like just an odd sound followed by a woosh lol. Only when I first pull away @ about 5 mph, last about 1 second then its gone until the next time the car is turned on again.
I also think it's exhaust related, does the sound go away as the car heats up?
Low RPMs exhaust components/shield can rattle and then go away as you pick up speed/rpms.
Old Aug 18, 2011 | 10:39 AM
Vivid Racing
Vivid Racing
Your ABS shouldn't be causing any vibration or making any sounds except for when you first start the car. when I read the OP, I assumed he's hearing the problem EVERY time he starts from a stop. As in, leaving a red light.
Old Aug 18, 2011 | 03:43 PM
TehkMob's Avatar
TehkMob
Maybe you have a bad yoke on the driveshaft?
cashmoney03
Sep 27, 2015 05:24 PM
AbyteZero
Sep 22, 2015 09:17 AM
RyansZ33
Sep 15, 2015 05:54 AM
PureR3d
Sep 10, 2015 06:23 PM
Daniel_dh
Sep 7, 2015 12:56 PM
