2 Dealerships, Still no luck :-(
Old Aug 27, 2011 | 04:23 PM
NissanTracker's Avatar
NissanTracker
Default 2 Dealerships, Still no luck :-(
Hey forums,
Need some help. I started suffering from a couple of issues. The first was loss of power after 4K rpms. Its very random. Sometimes it happens, sometimes it doesn't. If i get on it on the highway in 3rd... i get full power up to 4K rpms then its almost like it shuts fuel. My cruise control is not working either. Before anyone jumps the gun, no, i don't have aftermarket tail lights. Also, when i free rev in neutral, as the rpms come down, they seem to fall to about 300-400 and come back up. I thought it was an air leak....I cleaned the MF, cleaned out TB, re did my crawford plenum gasket with silicon gasket, What else can be causing this?
-NissanTracker
Old Aug 27, 2011 | 04:29 PM
NissanTracker
Sorry guys, forgot to add:
I have a 03 6 spd track. 56K miles. No Cel. I even got it checked to make sure that a p code was not tripping a cel. There was a problem before when i first purchased the car. If i was driving and went into neutral (pushing clutch down) the car would stall. This issue went away after going through some of the reset procedures... which i have done on multiple occasions. It solved the issues temporarily, but always came back. The idle dropping to 300 after free reving was always there.
-NissanTracker
Old Aug 27, 2011 | 05:45 PM
tony530's Avatar
tony530
Check ur vaccum hoses??.....also what have the dealerships tell you???
Old Aug 27, 2011 | 06:23 PM
NissanTracker
The dealership said they can't reproduce the problem. They say after they initiate a reset... cruise control works. They never did a full test on the power band. They just drive it normal. I asked them on several occasions to give her all she's got... but they in turn say they can't reproduce it. After i get the car... after 20 minutes, i loose cruise control and get the same power problem. I tried driving earlier and i got the power loss at 3K rpms... then it kicked in until about 3.8 K... then loss at 4K. While i was creaping awak from 4K, it seems as power kick in and out randomly up to 6K.. when i went into 4th... it was just dead. I was at 4-5K with no power at all... I'm very depressed about this.
-NissanTracker
Old Aug 28, 2011 | 11:48 AM
bottlefedZ's Avatar
bottlefedZ
Do you have loss of power on a cold start?
Old Aug 28, 2011 | 11:52 AM
Killabee350z's Avatar
Killabee350z
take the service Tech for a ride next time being they can't re-create the problem.Hope someone can fix your ride it's a bummer when your baby isn't running right.Good luck!
lolwatbro
Oct 9, 2021 04:58 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Cashwin
Oct 1, 2015 06:36 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
RyansZ33
Sep 15, 2015 05:54 AM
