Ticking sound from the engine Help please!
Old Sep 24, 2011 | 09:37 PM
cgrass's Avatar
cgrass
Default Ticking sound from the engine Help please!
A week ago, my 04's engine started making ticking sound
I currently have 86k miles on her
I'm not sure but i think the sound comes from the actual engine
It's like sth got loose inside
When its in N, it sounds
When I give a lil bit of gas, the ticking sound gets louder
And whenever I give up to 3000rpm, which i usually change the gear at, I can hear it clearly
Will it be the tappet that cause the sound
I will really appreciate if someone can tell me the problem
thanks for your time for reading this post anyway
Old Sep 24, 2011 | 11:20 PM
Mcutali's Avatar
Mcutali
Red face tick tock
checked oil level? maybe a good time to change oil make sure you have correct amount i put 5 quarts and 1/8 of a quart. usually when its burned up from oil consumption you can hear the valves ticking. my miata does the same ****.
Old Sep 25, 2011 | 12:14 PM
cgrass's Avatar
cgrass
I just checked the dipstick
the oil seems just at the normal range
thanks for your input anyway
Old Sep 25, 2011 | 12:17 PM
gs400speed23's Avatar
gs400speed23
I have the same problem! But ^no solution hope someone solves it for the both of us..
Old Sep 25, 2011 | 06:02 PM
Bmurray350z's Avatar
Bmurray350z
exhaust leak near the engine? eh idkk
Old Sep 25, 2011 | 08:07 PM
Jhunt37's Avatar
Jhunt37
This sounds very similar to the sounds I was experiencing before my car seized up a few days ago.. I was told by my mechanic that it was the flywheel (???) when i brought my car in the first time i heard it about 9 months ago.
I have an 06 manual and it burns oil. I did notice that when I put in more oil the sound seemed to go away. I check my oil about every other day though.. over the last few months the sound was always there. And now my engine is seized, still trying to figure out what the problem is although im almost certainly its not my flywheel.
Im starting to wonder if it was the valve ticking.. strange thing is: mine would only make the noise from 2500-3500 rpm. Is that what you experience or does the ticking go on up through redline?
Old Sep 25, 2011 | 10:10 PM
cgrass's Avatar
cgrass
I also thought that it would be the flywheel b4
Then i think the sound should be gone if i press down the clutch
but it didn't
It makes the sound even it is in Neutral
when the rpm gets up to 3000 then i press down the clutch to change gear right?! It gets louder cos i can clearly hear it
I never go up to redline, but i think it would be the same or louder sigh..
Old Sep 26, 2011 | 03:02 AM
r_seng's Avatar
r_seng
I've had the engine tick for some time now. Mine does not burn oil nor does it have problems. Still strong .
Old Sep 26, 2011 | 03:12 PM
cgrass's Avatar
cgrass
Ok i ve just done a oil change today
after a period of diving the sound seems gone
I will look more tmr when the engine is cool
hopefully it will be alright
besides mine doesn't burn oil either
And it's not 3000miles yet since my last oil change
but i notice the oil is a bit dirty and i do a lot highway mile a week
That's why i decided to go for a oil change
I'd pay 50 bucks to see if it is the way to solve instead of paying more dollars for the inspection
Old Sep 29, 2011 | 07:19 AM
znock_007's Avatar
znock_007
It needs oil; mine stopped make that awful clinking sound when I changed the oil. My mechanic said the car is burning oil too quick.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
