Door power lock/unlock and windows not working!!
Old Oct 1, 2011 | 07:50 AM
jdub1234's Avatar
jdub1234
Default Door power lock/unlock and windows not working!!
My power windows wont roll up or down and my power lock wont work at the switch or key fob. The passenger side door will lock and the trunk still pops open with the key fob but not with the button on the car???? Where should I look first for the problem? I did just install a remote start so could I have blown a fuse or is the BCM shot or what?
Thanks in advance!
Old Oct 1, 2011 | 08:00 AM
DavesZ#3's Avatar
DavesZ#3
Thanks in advance!
Your installation would be the first thing I would suspect. You might not have wired it properly. You could have a blown fuse. The install could have fried the BCM. Something may not be connected or put back together correctly.
Since the passenger side still works, I doubt the BCM is totally fried. Double check your work.
Old Oct 1, 2011 | 09:01 AM
jdub1234's Avatar
jdub1234
So what fuse should I check and at which fuse box. I looked on the fuse box covers and neither of them say anything about a power lock/window??
Diagrams would be nice if anyone has one
Old Oct 2, 2011 | 03:04 PM
jdub1234's Avatar
jdub1234
got it nm!!
Old Oct 7, 2011 | 07:40 PM
hotballsjohnson's Avatar
hotballsjohnson
How did you fix your problem i am having the same problem
Old Oct 11, 2011 | 02:52 AM
dbkobida's Avatar
dbkobida
got it nm!!
Hello, I am having the same problem with my windows and door locks. I does not appear that any fuses are blown. Could you tell me how you fixed your issue? Thanks.
Old Apr 28, 2012 | 03:15 PM
blAk mAx's Avatar
blAk mAx
Old Sep 15, 2019 | 09:07 PM
San Cheech's Avatar
San Cheech
Originally Posted by blAk mAx
2012
2019
Old Sep 16, 2019 | 04:13 AM
travlee's Avatar
travlee
Master
Originally Posted by San Cheech
2019
any reason you responded to a 7 year old dead thread?
Old Sep 16, 2019 | 04:16 AM
San Cheech's Avatar
San Cheech
Because I have the same problem
Old Sep 16, 2019 | 04:33 AM
travlee's Avatar
travlee
Master
then you should have stated that, we cant read your mind sir
Old Jan 5, 2020 | 05:25 AM
Vince Gould's Avatar
Vince Gould
Default Did you find a fix?
did you figure this out?
Old Jan 5, 2020 | 06:59 AM
travlee's Avatar
travlee
Master
He hasn't logged in for almost 7 years
07ZEKE
Aug 23, 2021 09:15 PM
codek
Sep 28, 2015 03:03 AM
