Car "slip" and abs kicking in on its own
Old Oct 13, 2011 | 10:44 PM
LunchBox20's Avatar
LunchBox20
Default Car "slip" and abs kicking in on its own
So recently my Z has started doing this and I'm confused as to why.
Moved to Cali and explored some of the very nice mountain, hill drives, and while driving, the slip light quickly flutters, and it feels like the car is trying to brake on its own.
I've noticed that the times that it does this, I was driving down steep hills.
Only thing recently changed on the car is the 2 rear tires that were replaced on the drive from TX to CA. Though I'm not sure why this would cause the car to act this way.
Would greatly appreciate any help, and thank you in advance
Old Oct 13, 2011 | 11:19 PM
R350Zz33's Avatar
R350Zz33
whats the specs on front and rear tires
Old Oct 14, 2011 | 09:53 AM
LunchBox20's Avatar
LunchBox20
Here are the tire specs
265/35-18
275/35-18
But I've been running this tire size since forever, why all of a sudden is the car doing this. Its like its trying to brake the car itself, as if I'm slipping?
zakmartin's Avatar
zakmartin
You're probably getting better traction on the rears than on the fronts, so the car is detecting slippage in the front and is tripping your VDC (assuming your car is equipped). It doesn't take much to activate your VDC, which is why unless it's raining, I usually turn the damned thing off. Do your rears and fronts have the same tread patterns?
Old Oct 14, 2011 | 10:10 AM
LunchBox20's Avatar
LunchBox20
Ah this is true, the rear tires are new with only 1k ish on them, where as the fronts are slightly older.
Thought they still have great tread and contact on them. I wouldn't think that would make the VDC activate like that.
Old Oct 14, 2011 | 03:13 PM
DaveJackson's Avatar
DaveJackson
Master
^I wouldn't think so, either... Unless those tires are way off in size (and it sounds like you checked, and they aren't) I don't know.
I have never found the VDC to be overly sensitive like the other poster said, though. I think something is wrong.
Old Oct 14, 2011 | 03:59 PM
Rear tire circumference is 1.08 percent greater than front. I assume you are running VDC ON.
Old Oct 14, 2011 | 06:30 PM
sw33tz's Avatar
sw33tz
My car is doing the same thing, I have however put in 4.08 gears, I do have 20" tires on the car with the rears being 10.5" wide. My car will show slip under hard acceleration even if I am not slipping, very frustrating as the car is retarding the throtle.
I need help! Had the car checked and they can not find anything.
Old Oct 14, 2011 | 07:07 PM
LunchBox20's Avatar
LunchBox20
See its not throwing any codes when I used the OBD2 scanner. I figured something would have some up if that was the case, right?
Its scary though when it happens. I could be in a lane next to another car, and then it happend and the car was jerky and it felt like 3 calipers were trying to stop the car, and one wasn't causing the car to wiggle...and at speed thats scary
Old Oct 15, 2011 | 04:57 AM
Shizzmaster2k's Avatar
Shizzmaster2k
Did you have your wheels rotated at all when you had your vehicle serviced last?
Old Oct 15, 2011 | 09:35 PM
LunchBox20's Avatar
LunchBox20
I had the front wheels re balanced, and rotated the tires, and had the new tires put on the rear of the car and balanced.
I've come to the conclusion with the help of another, that the rear tires are sticking, thus making the VDC think that the front wheels are losing grip.
Old Nov 3, 2011 | 05:18 AM
McLovin350Z's Avatar
McLovin350Z
any update?
im having the same issue
Old Jan 23, 2012 | 03:46 AM
LunchBox20's Avatar
LunchBox20
It is believed to have been the fact that the rear tires were gripping while the worn fronts were slipping.
Old Jan 24, 2012 | 06:20 AM
McLovin350Z
So you replaced your front tires to confirm this?
I'm having a similar issue so your feedback will be helpful
Thanks
Old Jan 25, 2012 | 10:37 PM
Dragonbreath's Avatar
Dragonbreath
An out of wack alignment will also cause this to happen.
And yes, worn front tires and new back tires can (and vice versa) can cause this, especially in sharper curves.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
Mikey R6
Sep 19, 2015 01:48 AM
