07 OEM Bluetooth Issues
Old Oct 21, 2011 | 10:25 AM
MagnuM45's Avatar
MagnuM45
Default 07 OEM Bluetooth Issues
Hi all,
When I first bought my 07 about 8k miles ago, I went through the sync process with my iphone 3gs and it worked perfect. I had no problems for a few months and it would find my phone and sync like it should when I got in the car.
Then it just stopped syncing one day. I didn't change anything or do anything different (same phone, still no audio upgrades of any kind). Now when I try to sync my phone and go through the whole pairing process, everything works initially and I can make a call and such. Then I shut the car off and when I come back, its forgotten everything. Is there anyway to reset the bluetooth or do I have to reset the whole ECU? Can I just take the leads off the battery to do this or do I have to do the weird gas pedal thing?
Couldn't find anything similar searching....anyone heard of this issue???
Old Oct 21, 2011 | 01:41 PM
zakmartin's Avatar
zakmartin
I'd blame the phone before I blame the car. Have you tried syncing another phone to your system to see if it works?
Old Oct 21, 2011 | 02:06 PM
Duckeee's Avatar
Duckeee
sounds more like a phone problem than anything.
if it helps im local to you if youd like to test my phone
Old Oct 23, 2011 | 04:44 PM
MagnuM45's Avatar
MagnuM45
Ok I messed with it again, still doing it. I paired the phone, made a call, all is fine. I then shut the car off and wait a min, turn it on again and when I hit phone it says "no phone is paired..." My iPhone still remembers that it has that device saved but the car forgets the phone.
What should I try now?
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
