05 DE cranks wont start
Old Oct 29, 2011 | 04:42 PM
phatchops42's Avatar
phatchops42
Default 05 DE cranks wont start
As the title states the car cranks and cranks but only starts on rare rare occasions. Has been fine up until today just out of the blue wont start. Fuel pump is working as I can hear it and it stinks like fuel. When it does fire it dies almost instantly. Car has no SES lights and when hooked up to cipher its showing that timing is only advancing 5 degrees. From what I was told it should be around 30. Im leaning towards a cam sensor but would appreciate some input from the brilliant minds here. Thanks in advance for the help.
Old Oct 29, 2011 | 05:33 PM
konrad's Avatar
konrad
what code are you getting? did you scan for codes?
Old Oct 29, 2011 | 05:52 PM
phatchops42
no codes
Old Oct 30, 2011 | 06:12 AM
tyz's Avatar
tyz
Verify correct key or try second key. I switched up keys on a Z and a G cars they cranked just fine but would never start. Possibly bad chip in key.
Old Oct 31, 2011 | 08:57 AM
phatchops42
Tried the other sets of keys and still nothing. Any one have any other ideas?
Old Oct 31, 2011 | 10:19 AM
zakmartin's Avatar
zakmartin
Do a bench test on your CPS (your car should have picked it up if it's a bad CPS and thrown a code, so I doubt that's the problem). Could be a tank of bad gas. Did this happen shortly after filling it?
Old Oct 31, 2011 | 02:40 PM
phatchops42
The gas is possible but I went through a half tank before the problem started, however, the shop I brought it too is going to test the fuel and probably purge the whole fuel system.
sherm
Apr 11, 2020 05:21 PM
