Wheel Bearing and Hub Assembly Problems?
Old Nov 2, 2011 | 05:22 PM
Gozirra's Avatar
Gozirra
Default Wheel Bearing and Hub Assembly Problems?
So I recently started having a type of thumping from the rear driverside wheel.The sound is similar to having something stuck to the wheel. I thought the wheel needed balancing but there was no vibration> I lifted the car up and the wheel has play even though all the lugs are tight. We ordered a brand new wheel and hub. I went and got it pressed at a local machine shop. He seemed to press it until it coudnt go any further.
Problem is, the assembly dosnt look fully pressed according to the pictures on the internet.
Here is what I have:
And some pictures of what its supposed to look like:
http://www.am-autoparts.com/Nissan/3...47/533585.html
Anyone know whats going on? How can I fix this? It would really freakin suck if this was 200 bucks down the drain.
Looking forward to replies,
Leon
Attached Thumbnails Wheel Bearing and Hub Assembly Problems?-img00045.jpg   Wheel Bearing and Hub Assembly Problems?-img00047.jpg   Wheel Bearing and Hub Assembly Problems?-img00048.jpg
Old Nov 2, 2011 | 09:44 PM
winchman's Avatar
winchman
That's definitely NOT pressed in all the way. The '07 service manual says it takes 11,000 pounds pressure to fully seat the axle in the bearing.
Be sure he's supporting the bearing properly in the press. I'd take it to a Nissan shop, since they'll have the correct tools.
Old Nov 3, 2011 | 02:48 AM
McLovin350Z's Avatar
McLovin350Z
be aware that the picture you should was of a front wheel bearing assembly which comes from the factory built-up
only the rear bearings (which are different) require to be pressed in and probably do differ in appearance.
Old Nov 3, 2011 | 08:31 AM
winchman's Avatar
winchman
OK, here's an image of the rear hub assembly. It has a shoulder that fits against the bearing, and that's where it stopped when the machinist pressed it into place. It's good to go.
The radius closer to the outer end looks like it should go against the bearing, but obviously that's not the case.
Old Nov 5, 2011 | 02:56 PM
Gozirra's Avatar
Gozirra
The assemby was a perfect fit and was pressed perfectly. There are no more sounds and car is running great!
THanks everyone for the replies! Hopefully this will help anyone who has doubts in the future.
Link to DIY for rear bearing replacement which I followed:
http://g35driver.com/forums/brakes-s...g-removal.html
Depravity
Oct 1, 2015 04:49 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
samansharif
Sep 25, 2015 12:31 PM
