HELP: low speed clunking/click when turning
Old Nov 12, 2011 | 10:11 AM
ac419's Avatar
ac419
Default HELP: low speed clunking/click when turning
hi everyone,
i need some serious help. i've tried search and still cant find an answer. when i turn my car at low speeds, i get a clunking/click in the front end. my car is a 2006 G35 coupe, never been in an accident and was recently aligned.
i have had some parts replaced in the front, SPL compression rod bushings, whiteline LCA bushings, whiteline lower outer bushings, and Tein inner and outer tie rods.
it's been absoulte headache and i hope someone can help me.
thank you,
Alex
Old Nov 12, 2011 | 10:17 AM
VQdriver's Avatar
VQdriver
Do you have an aftermarket limited slip clutch type differential? Sounds like you do..Ooops I just read the rest of the post lol. I'd check all your parts. Why'd you get those replaced? It's still a relatively new car. Sometimes aftermarket "upgrades" are FTL
Old Nov 12, 2011 | 11:21 AM
ac419's Avatar
ac419
i had those parts replaced because my bushings were torn
i guess i've been lowered for too long.. lol
Old Nov 12, 2011 | 11:34 AM
Duckeee's Avatar
Duckeee
do you have coilovers?
Old Nov 12, 2011 | 11:52 AM
ac419's Avatar
ac419
i do have coilovers lowered on KW Variant 2 with a 1 finger gap all around
Old Nov 12, 2011 | 12:21 PM
Duckeee's Avatar
Duckeee
could be that your front springs have dirt buildup and clunk when you turn. try cleaning or spraying something on the top and lower perch. could also be too much preload which increases the problem.
when i had my s13 on megan coils it clunked all day but crappy coils are known for that. you have fairly nice coils so i im not sure.
Old Nov 12, 2011 | 01:50 PM
ac419's Avatar
ac419
sorry to sound like a newb.. but what's preload?
Old Nov 12, 2011 | 02:32 PM
Could be any part of the front suspension. "Low speed" just masks high speed noise - that is why you hear it at low speed. Have a mechanic get under the car and take a look.
Old Nov 12, 2011 | 09:55 PM
JDMStanced's Avatar
JDMStanced
try adjustable endlinks.
i got mine from ams motorsports
Old Dec 12, 2011 | 10:06 AM
ac419's Avatar
ac419
i have my front endlinks with spl but still there, my mechanic said it might be the top shock mount going bad
Old Dec 15, 2011 | 09:04 AM
bikinilust's Avatar
bikinilust
Make sure the top shock mount nuts r tight.....
Seen it before.
What will really help is for you to pinpoint the location of the noise.
Left? Right?
Does it make the noise on left turns? Right turns? Both directions?
does it occur in reverse?
and when did u start noticing the noise?
what was the last thing done to the car prior to hearing the noise?
Clicking/clunking could be a number of things, so figure out the answers to the above questions and one can give you a better prediction of what the problem is
Old Dec 17, 2011 | 12:55 PM
ac419's Avatar
ac419
Seen it before.
Left? Right?
thanks for your response.
-sound appears to be coming from both the drivers and passenger front
-the noise comes from turns both directions
-does not occur in reverse
-noise has been going on for a year or two now (been awhile)
-last thing done to the car was SPL endlinks and SPL compression rod bushings installed
i currently have SPL endlinks, SPL compression rod, Tien tie rods inner and outer, and Whiteline LCA bushing replaced.
i hope this helps. thanks!
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
