lights not working
Old Nov 18, 2011 | 01:35 PM
TurboTom's Avatar
TurboTom
Default lights not working
Last night I got in my car and noticed that the lights on the radio weren't lit up. (the screen was but the buttons weren't). Today around 4am I was driving to work and noticed that my taillights and license plate lights weren't on. When I hit the brake they lit up but once i let go they went off. It can't be the lights because I dought they would all burn out at the same time, and it can't be the switch by the steering wheel because the headlights and other interior lights go on when i turn it. Any ideas
Old Nov 18, 2011 | 01:38 PM
TurboTom's Avatar
TurboTom
I don't know if this is relevant or not but I did just replace my brocken 07 headlights with new 07 headlights with the iron man mod and switchback corner leds, and the demon eye mod on wednesday.
Old Nov 18, 2011 | 01:52 PM
TurboTom's Avatar
TurboTom
im checking the fusses now and so far they all look good
Old Nov 18, 2011 | 05:23 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
my money is on a blown fuse
Old Nov 18, 2011 | 10:40 PM
R350Zz33's Avatar
R350Zz33
lots of fuses lol
Old Nov 19, 2011 | 01:54 PM
TurboTom's Avatar
TurboTom
Checked all the fuses in both boxes, switched fuses with the same numbers around too..still nothin ..any other thoughts ?
Old Nov 19, 2011 | 05:22 PM
TurboTom's Avatar
TurboTom
bump
Old Nov 19, 2011 | 05:31 PM
SparkleCityHop
Living in 350Z
I can't verify/vouch for this, but this is what Google told me:
"there is a 3rd fuse box located on the left side of the battery, remove battery cover, then remover the plastic piece the battery cover is set into by removing the plastic holding pins using a flat head screw driver to pop up the center. then remove the passangerside air vent cover (atached to the 2nd plastic piece). then there is a cover to the IPDM (intelligent power distribution module), the fuse for the tail lights is the top left 10a fuse. if this solves your problem then great, but if you replace this fuse and he keeps blowing on you then the problem is with the relay inside the IPDM."
Even better, this thread has instructions and pictures: https://my350z.com/forum/exterior-an...ight-fuse.html
Old Nov 19, 2011 | 05:38 PM
TurboTom's Avatar
TurboTom
thanks, ill go check it out right now
Old Nov 19, 2011 | 06:14 PM
TurboTom's Avatar
TurboTom
Thank you sparklecityhop...there is a third box and #71 fuse was blown...problem solved , I still don't know y this wasn't in the manual ...once again thank you thank you thank you
Old Nov 19, 2011 | 07:13 PM
SparkleCityHop
Living in 350Z
No problem, man. Plenty of folks have helped me out on here when I was in a pinch. That's why I'm glad the forum's here. It's always been worth the $30 Premier Membership to me because of how much money it's saved me over the years.
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
