My 2003 Nissan 350z is idling high.?
Old Nov 26, 2011 | 06:24 PM
poncholee's Avatar
poncholee
Default My 2003 Nissan 350z is idling high.?
Hi need help with this its a bit frustrating. I installed a new throttle body with gasket and now it is idling at 1k and 1,2k with a/c on. It was doing the same thing prior to the install I figured it should fix the problem. but it hasn't. i have done the relearn and ecu reset. With the relearn it would drop the the rpm to 750, when when i start the car it would go back to 1k. the SES lights goes back on. i have had the code read and each time its p0507. anyone have a clue on whats going on? i killed the battery in hopes it reboots everything.
Old Nov 26, 2011 | 06:27 PM
mr. sparco's Avatar
mr. sparco
Check all vacuum hoses, intake manifold/upper plenum for leaks.
Old Nov 26, 2011 | 07:06 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Is everything stock/OEM or do you have mods?
Old Nov 26, 2011 | 07:28 PM
poncholee's Avatar
poncholee
the car is stock.
Old Nov 26, 2011 | 07:53 PM
Deteria's Avatar
Deteria
whoops posted in wrong page
Old Nov 27, 2011 | 05:28 AM
DavesZ#3's Avatar
DavesZ#3
Disconnect battery overnight. Reconnect next day, do first two relearns steps from here...
https://my350z.com/forum/6008226-post2.html
Drive car around to get engine hot then repeat all three relearn steps. I was having the same problem about two months ago then ran across several threads from people who couldn't get their idle to stabilize or drop to 750 - their solution was the hard reset of the ECU.
Old Nov 27, 2011 | 05:37 AM
taywan's Avatar
taywan
same what dave said, i did all relearns and didnt do much until i disconnected batt overnight, and next morning, it was fixed after warm-up. one of the steps should clear the c.e.l. tho.... u had the prob before tho?? then u replaced the t.b.?? if u didnt disconnect batt before install also..GL
Old Nov 27, 2011 | 06:10 AM
poncholee's Avatar
poncholee
thanks for the feedback. i disc the battery for two hours and the idle went back to normal.
Siqcology
Sep 18, 2019 01:45 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
hardkicks
Sep 20, 2015 12:28 PM
EnjukuRacing
Sep 11, 2015 08:30 AM
