What causes my "loose" suspension feeling
Old Dec 1, 2011 | 07:08 AM
ericjackson's Avatar
ericjackson
Default What causes my "loose" suspension feeling
My car has felt like this for some time. Certain roads i feel like the car is moving left and right under me while im driving straight and im not sure what causes it. The only way i can describe it is this sign, lol. Basically, im driving straight, but it feels like the wheels are doing this:
I know i need new endlinks and i have new sway bar bushings that i need to put on the rear but the nut is stripped so i havent had time to get it off.
My mods are eibach pro kit, tokico d-spec struts, hotchkis sways, solid diff bushing, and whiteline front lower translink bushings. The tires are fairly new but it did this before as well. I do not know a lot about troubleshooting suspension problems so im hoping someone may have a clear answer. hopefully its one of the things I already know i need to replace. One rear hub/bearing is practically brand new. Ive jerked on all the wheels and they do not feel like they have any play in them like the one that i had to replace twice last year.
Old Dec 1, 2011 | 07:12 AM
Russ@Z1's Avatar
Russ@Z1
Uneven roadways where grooves have been worn in by long term use without being fixed or repaved.
Alignment settings.
Bad suspension components. For example, bushings, ball joints, tie rods, struts, springs, etc.
Old Dec 1, 2011 | 07:14 AM
lgear080's Avatar
lgear080
LCA's fo sho. In addition to every other bushing.
How many miles you got? Good news - it can be fixed,
Bad news - its spensive.
Old Dec 1, 2011 | 07:17 AM
ericjackson
what is LCA? my plan this winter was to re-do all bushings and go with whiteline or something comparable. but i just dropped a lot of money into swapping out my engine
i have 150k so im sure the bushings are worn out. i didnt know if this particular problem could be "narrowed down" or not by someone who has had the same problem.
edit, and i have had my alignment done 4 times until they got it right this year.
Old Dec 1, 2011 | 07:20 AM
ericjackson
ah lower compression arm? is that the one that tears whenever you lower the car? i do plan on fixing that one as well with the solid one that jason used in his DIY
Old Dec 1, 2011 | 07:26 AM
lgear080's Avatar
lgear080
There is a reason none of your alignments worked.
Your bushings/lcas were shot.
I found this out by 110k miles.
Search LCAs on the site as there are a few writeups and diy.
Old Dec 1, 2011 | 08:29 AM
the3kgt2's Avatar
the3kgt2
If you have wider low profile tires, it could just be tramlining.
Old Dec 1, 2011 | 08:35 AM
jebz240's Avatar
jebz240
I had the same issues when mixing aggressive tire treads.
Old Dec 1, 2011 | 08:58 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
LCAs would be my 1st bet as well. When shopping for bushings, keep in mind that polyurethane (PU) bushings are stiffer than stock. If you're ok with sacrificing a little bit of comfort to get a better handling car, go poly for sure. They tend to last a bit longer as well.
Old Dec 1, 2011 | 09:04 AM
ericjackson
yeah i def do not care about the stiffness. i drive my car to work with the same settings i use for autox. i thought about going with solid bushings in a few places where available just because my solid diff bushings already put me in SSM class for scca anyway.
Im going to replace the lca bushings first. thanks for the help.
Old Dec 1, 2011 | 09:58 AM
bmccann101's Avatar
bmccann101
i am standing up at my desk doing the slow clap for you OP...
THE most 100% EPIC thread title.
Period.. hands down.. FTW.
bahaha.. i think this was the name of a pamphlet i saw while i was in the waiting room during my chicks annual exam.
I was dying laughing before i even clicked into the thread link.
Old Dec 1, 2011 | 10:09 AM
terrasmak's Avatar
What size tires are you running? When my car was stock , and still today, anytime i run a tire combo of equal or very close to equal in height my car gets really loose.
Old Dec 1, 2011 | 10:56 AM
AngelsVQ's Avatar
AngelsVQ
maybe check the most basic, tire pressure
Old Dec 1, 2011 | 11:00 AM
ericjackson
^ yeah thats def not it. ive ran anywhere from 30psi warm to 35psi cold. same feeling. also on my a6's... but thats a totally different tire. same feeling though.
Old Dec 1, 2011 | 06:14 PM
lgear080's Avatar
lgear080
your mileage and lack of previous replacement says it all.
think of all that money wasted on alignments for a car that couldn't be aligned
Old Dec 1, 2011 | 06:20 PM
ericjackson
I paid $20 for the alignment cause I knew the manager. The other 3 were free and I did it because of uneven treadwear. Treadwear has been good since so I don't think it was money wasted. I do,however, want to fix this problem as well.
Old Dec 1, 2011 | 06:24 PM
jebz240's Avatar
jebz240
I also had some weird issues and ended up getting my tires precision balanced with one of the laser balance machines. Fixed my problems..
Old Dec 1, 2011 | 10:49 PM
terrasmak's Avatar
So what size tires are you running. As mentioned above, anytime i run a square setup (non staggered in height) my car does the same thing. I believe its cause by the change is caster angle and the change is weight distro on the chassis.
Also the compression bushings will be trash. You mention using A6's, i highly suggest running the SPL monoball bushings. The replace the LCA bushing while your in the area.
Old Dec 3, 2011 | 05:51 AM
DaveJackson's Avatar
DaveJackson
Master
Mine does this, but only on icy roads so I don't think there is anything wrong with mine.
Old Dec 3, 2011 | 08:38 PM
ericjackson
my sizes on the street are 255/45/18 R and 245/40/18 F and A6's are 295/35/19 R and 285/35/18 F.
Im confused, i thought the compression bushings and LCA's are the same thing? I thought it was referring to the compression arm. I have changed my lower translink bushings out last year to whiteline and those are still fine. Less than 5k on them for sure.
this is what i will be doing next. https://my350z.com/forum/brakes-and-...g-install.html
with a set of rear bushings and front soon after if not during. because i knew the bushings are wore out. i just want to make sure that solves my swaying problem. Because i have been debating on endlinks first before the bushings. I want to fix my current problem before "upgrading" something.
