C1130 engine 1 fuel cut
Old Dec 5, 2011 | 04:14 AM
SKIN's Avatar
SKIN
Default C1130 engine 1 fuel cut
Before I end up going to the Wlmg , I recently had the 'mi' 'ESP ' 'slip' warning lights on , with the sudden lose of power took it to a Mac mate who plugged the diagnostics n come up with the fault code regarding the cam pos sensors , have renewed the B1 and B2 sensors and cleared the fault codes , only to restart and the same problem coming up and then C1130 engine 1 fuel cut , now i think the C part means its a Nissan faut code where as the PO codes are general faut codes , can anyone shed some light Cheers
Old Dec 5, 2011 | 08:44 AM
DavesZ#3's Avatar
DavesZ#3
See post #9 here....
http://g35driver.com/forums/g-spot/2...ights-all.html
Old Sep 14, 2020 | 06:34 AM
raymond04g35's Avatar
raymond04g35
Default problem solved with my 04 g35
after reading all the post and replacing both cam sensors, crankshaft position sensor, throttle body, all o2 sensors and still had the same issue of fuel cut out along with abs,vdc,slip and service engine soon lights on I decided to check all my grounds and clean them upon doing so I replaced both positive and negative battery cables and then all my problems were resolved I probably didn't need all the sensors just the battery cables hope this helps
Cujucuyo
Dec 24, 2019 03:07 AM
lord_kinboat
Jan 22, 2019 07:00 AM
Stacherash
May 8, 2018 05:57 PM
MichaelaZ
May 6, 2016 10:18 AM
Unbootable
Tuning
Sep 2, 2013 05:07 AM
