Installed HD CSC and now clutch wont bleed! help!!
Its the bleeder screw on the bell housing...why would you need a picture of that?
Regardless, here is a pic to give you an idea:
[picture]http://www.carbonetic.net/blog/blog/wp-content/uploads/2007/03/resize0014.jpg[/picture]
The only difference with mind is that i have a hydraulic throw out bearing instead of a slave and clutch fork.. So where the clutch fork is coming out of the transmission in the picture i have 2 hydraulic lines (one being from the master and one coming out of the bell housing as the bleeder line.
laurentj23 - here is a pic from the shop manual. The bleed location is similar for the heavy duty CSC.
Attachment 329225
Attachment 329225
Ok as an update, i was able to use the gravity bleed method and it worked GREAT for about a month, i also took apart the master and cleaned it out it was extremely dirty fluid in there that i guess just didnt wana bleed out.
Now this weekend im starting to have lack of pressure again like i have air in the line...hmm
Could it be my master needs to be replace/rebuilt? Should i try gravity bleed one more time before i do that? Just want some opinions before i make any purchases. Car is driveable but the pedal is just not returning all the way...blah!
