What could be causing this?
Old Dec 13, 2011 | 11:17 AM
STL 350Z's Avatar
STL 350Z
Default What could be causing this?
I took my Z to a local dealer where the diagnosis was "We can't find anything wrong with your car" for issues with the clutch and burnt clutch smell. I left and have been driving it like normal since... I leave a friends house last night and this is what happened:
Started car and check engine light came on.
Went to pull out and had no gas petal, would not rev up even if pushed to the floor.
Restarted car and check engine light remained on but ran fine.
I live 45 mins from my friend and halfway the Z started smelling of burnt clutch.
Pulled over, car smelling of strong burnt clutch, figured I would sit for a few.
Went to pull out and once you let the clutch out in 1st you could feel the clutch chatter really bad and the entire drive train shook.
Shifting into 2nd and 3rd results in clutch slippage but 4th,5th and 6th shift smoothly.
Also I drove it this morning and it's driving just fine, shifts and pulls out like it should, check engine light is still on.
What is going on here? Z has 107,000 miles...
Old Dec 13, 2011 | 11:40 AM
Junkster's Avatar
Junkster
whats your CEL for???
check the codes would be your FIRST step IMO
Old Dec 13, 2011 | 11:43 AM
Junkster's Avatar
Junkster
BTW, it could be something wrong with your clutch plate or Pressure plate...but that shouldnt be throwing a CEL...
Old Dec 13, 2011 | 12:07 PM
STL 350Z's Avatar
STL 350Z
Going to get the code pulled after dinner tonight at Advance Auto. I find it odd that the car drives fine once it sits over night then acts up after 30mins or more of driving.
Old Dec 13, 2011 | 12:48 PM
Junkster's Avatar
Junkster
Wait...when was the last time you changed your clutch???
I could be that your clutch is pretty much gone....
Old Dec 13, 2011 | 12:51 PM
Trigo_'s Avatar
Trigo_
Replace your Clutch and you might as well replace your flywheel also
Old Dec 13, 2011 | 12:55 PM
Junkster's Avatar
Junkster
Yea you cant resurface the OEM flywheel IIRC.
but now that i come back and read this, im willing to bet you a nickle that you need to replace your clutch lol...the code should be unrelated
Old Dec 13, 2011 | 02:33 PM
STL 350Z's Avatar
STL 350Z
P2135 code.
On mobile be back later
Old Dec 13, 2011 | 02:40 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
That code is for the drive by wire system. TPS sensor is the most likely culprit.
Clutch issue is unrelated.
Old Dec 13, 2011 | 05:48 PM
STL 350Z's Avatar
STL 350Z
Didn't think the clutch would throw a light... friend of mine drove it tonight after pulling the code and said the clutch is def going out and the dealers mechanics didn't know their heads form a hole in the ground.
Not sure what to do about the P2135 TPS code though.
Old Dec 13, 2011 | 05:53 PM
RMichael's Avatar
RMichael
look it up.
Old Dec 13, 2011 | 07:04 PM
STL 350Z's Avatar
STL 350Z
Originally Posted by RMichael
look it up.
I plan to.
Old Dec 14, 2011 | 02:47 PM
STL 350Z's Avatar
STL 350Z
Ok as far as the clutch goes I have decided to do it myself. Should I replace the flywheel since the car has 107k miles? If I should I will probably go with the Z1 350Z / G35 Clutch and Flywheel combo.
I have read up on the install and it states the exhaust has to come off. I assume at 107k miles the bolts may break or be rusted and if that happens whats the best course of action? I will need new gaskets too wont I?
Old Dec 14, 2011 | 02:58 PM
Neimad's Avatar
Neimad
Gaskets, bolts and a whole lot of patience letting the PB stuff sit till the bolts are loose. Get a propane torch to heat the bolts too. Maybe just get a aftermarket exhaust too.
Old Dec 14, 2011 | 03:16 PM
STL 350Z's Avatar
STL 350Z
Don't have the funds for an exhaust right now or I would.
loudtoyz
Apr 6, 2023 04:52 AM
wanderingstuden
Jan 28, 2016 07:03 PM
_bit
Oct 2, 2015 07:49 AM
Cashwin
Oct 1, 2015 06:36 AM
