Shifter sitting extremely low. Broken tramission mount?
Old Dec 18, 2011 | 09:03 AM
TriniSpec's Avatar
TriniSpec
Default Shifter sitting extremely low. Broken tramission mount?
Whatsup guys, i'm about to buy a Z as a winter project. I am wondering why the shifter is so low picture below, I know thats not a SSK. .Or is it Maybe someone can offer some insight about this problem, i was thinking it could be a transmission mount. Has this happened to anyone around here? The car is hit fairly hard, frame is straight. Thanks, any insight would be appreciated
Thanks guys
Old Dec 18, 2011 | 09:22 AM
ian99rt's Avatar
ian99rt
Well a failed OEM bushing would not allow the shifter to drop that low.
The fact its centered, I'm guessing the transmission isn't supported and is just hanging.
Old Dec 18, 2011 | 09:53 AM
midz350's Avatar
midz350
Why don't you look under the car and see for your self?
Old Dec 18, 2011 | 10:21 AM
TriniSpec's Avatar
TriniSpec
The car is not in my possesion ATM.
Old Dec 18, 2011 | 11:15 AM
silvertouringz's Avatar
silvertouringz
in for more pics
Old Dec 18, 2011 | 12:01 PM
JCITY's Avatar
JCITY
Just install a longer shifter!
No,just kidding.
The shifter is sitting so low I'm surprised its not on the ground.
Obviously,just hanging there.
Old Dec 18, 2011 | 01:51 PM
TriniSpec's Avatar
TriniSpec
As for pics the front end is pretty f*cked up.
That damn plastic cover is blocking the intake plenum so I can't quite tell if the motor mounts broke and the engine is pushed back. I was trying to judge where the strut bar goes across the intake plenum, but I can't really see ****.
I'm no Z expert, but judging where the oil filler cap SHOULD be, looks like the engine is pushed back, correct me if i'm wrong.
The actual car, yes it's an insurance auction..
It's a 03, both front airbags blown, the frame horns may need pulling as the bumper support is damaged..
Old Dec 18, 2011 | 01:59 PM
TriniSpec's Avatar
TriniSpec
I'm thinking I should walk away from this, looks like the engine is pushed back into the firewall, judging from other Z's.
This Z has a pretty significant gap between the I/M and the firewall.
Old Dec 18, 2011 | 02:01 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
RUN!
Why would you even want to bother with rebuilding that?
That car is so messed up.
RandomHer0's Avatar
RandomHer0
Jesus, walk away dude.
Old Dec 18, 2011 | 02:38 PM
terrasmak's Avatar
you better get that for under $2k if you buy it.
Old Dec 18, 2011 | 06:34 PM
TriniSpec's Avatar
TriniSpec
Possible theory, transmission crossmember support thing broke tilting the shifter way down and also tilting the engine back. I'm trying to look at this on the bright side, airbags for the 350Z also aren't cheap. Car is selling tomorrow, i'll try to get into it for cheap. BTW, the car has 105k miles on it.
Old Dec 19, 2011 | 04:44 AM
silvertouringz
the engine IS pulled back! the strut bar shoulf be over the plenum which is not. u can get less damaged cars. which site r u looking on?
Old Dec 19, 2011 | 11:10 AM
djamps's Avatar
djamps
Engine is almost a foot back from where it should be. shifter linkage is probably severed and the stick is just holding on by the boot. You sir, have big bawls if you plan on fixing this.
Old Dec 19, 2011 | 11:43 AM
La_Fiebre's Avatar
La_Fiebre
Default OMG!!!!!
Old Dec 19, 2011 | 11:50 AM
konrad's Avatar
konrad
If you want a g35 coupe as a project there is one in NJ front and rear damage , but a lot better than this , for $3400 03 6mt
Old Dec 19, 2011 | 12:17 PM
Shizzmaster2k's Avatar
Shizzmaster2k
On to the next one. High risk. Low reward with this Z but there is always potential if your crafty with the tools and plan to turn this into the next big DIY project. Good luck OP!
Old Dec 19, 2011 | 01:29 PM
bmccann101's Avatar
bmccann101
Originally Posted by La_Fiebre
^^^this is why the internet was created..
im going to p!ss my pants dude.
Old Dec 21, 2011 | 09:55 AM
Heritage's Avatar
Heritage
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
