drivers window
Old Dec 23, 2011 | 06:47 AM
71undercover's Avatar
71undercover
Default drivers window
need help, the drivers window rolls up on auto but then rolls down 1/2 way when it hits the top. before you ask there are no obstructions for the sensor to detect, is there a adjustment that can be made on the sensitivity of the sensor or do i have to bring it back to the dealership to fix it.
Old Dec 23, 2011 | 07:08 AM
flecko28's Avatar
flecko28
http://g35driver.com/forums/attachme...untitled-1.jpg
Same for the Z even though its on g35driver.
Old Dec 23, 2011 | 09:30 AM
microsteve40's Avatar
microsteve40
Know it all
My windows have done that as a result of the brushes in the window motor getting dirty. There are a lot of threads on here about that, and how to deal with it. After cleaning the passenger side 3 times, I finally had to replace it, and the driver side was just cleaned for the first time this week.
Old Dec 23, 2011 | 10:00 AM
VO...'s Avatar
VO...
Administrator
I'd perform the window reset procedure. You've gotta remove the panel though. That's what I would do...
Old Dec 27, 2011 | 05:39 PM
71undercover
Thumbs up
thanks ill try that this weekend
Old Dec 27, 2011 | 05:44 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
+1 to what Vo said
Old Dec 28, 2011 | 05:13 PM
Itzcashew's Avatar
Itzcashew
You need to clean the motor or replace it. Resetting it will just stop it for a bit then it will resume doing that.
Old Dec 29, 2011 | 06:59 AM
SmoothZ's Avatar
SmoothZ
Well, if you clean it or replace it, you still need to perform the reset procedure.
lapham3
Oct 7, 2022 03:15 PM
Siqcology
Sep 18, 2019 01:45 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
