08 tails swapped into 05.... FUSE KEEPS BLOWING
Old Jan 22, 2012 | 07:25 PM
m808six's Avatar
m808six
Default 08 tails swapped into 05.... FUSE KEEPS BLOWING
Had the lights swapped for near 2 months with no issues, now for some reason the running lights in the led tails and the license plate frame light keep blowing.
It's a small 10 fuse near the battery in the IPDM box. That same fuse seems to power the rear running lamps. I replaced the fuse and in about a day it blew again. Any ideas what might be causing this issue? I don't want to put in a larger fuse and have the issue sent further up the chain and blowing something important. Ideas?
Old Jan 22, 2012 | 07:44 PM
johnwigs's Avatar
johnwigs
high amperage
Old Jan 23, 2012 | 05:38 AM
cgkp0925's Avatar
cgkp0925
A short somewhere?
An exposed wire touching metal will cause this.
Old Jan 23, 2012 | 06:31 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
fake rear tails? never seen an issue with the genuine Nissan ones
Old Jan 23, 2012 | 04:42 PM
m808six's Avatar
m808six
All 2008 OEM heads and tails. Not into the eBay stuff.
Old Jan 23, 2012 | 04:51 PM
m808six's Avatar
m808six
I'm assuming that it might be an exposed wire how CGK said. I need to pull off the bumper again and check the wires for the license plate lights
Old Jul 12, 2012 | 07:59 AM
m808six's Avatar
m808six
simple fix yet, not "fixed"
i noticed that when i leave my lights on when i start my engine it was probably creating a surge of edgy due to most likely a lose ground some where that we were unable to start....
now when i gas up, lights off
step out and cut car off, lights out
i only turn lights on after motor turns over.... since I have started this series of techniques I have not blown a fuse.
good luck and hope this works
Old Jul 12, 2012 | 08:18 AM
Duckeee's Avatar
Duckeee
resistor?
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
