All 4 tires have slow leaks? TPMS leaking?
Old Feb 19, 2012 | 08:56 PM
paulmess7's Avatar
paulmess7
Default All 4 tires have slow leaks? TPMS leaking?
Hello,
I just got new wheels (Konig 7.5x18) to replace my stock 8x18's.
Now I have slow leaks coming from all 4. Were they not mounted properly, or is it because I didn't purchase tpms rebuild kits?
They lose about 2-3psi a day.
Thanks for the feedback guys
Old Feb 19, 2012 | 09:55 PM
deeno's Avatar
deeno
I'm going to say not mounted properly ...but all 4?? Idk
Old Feb 20, 2012 | 12:06 AM
paulmess7's Avatar
paulmess7
If it makes a difference, these are the rims:
http://www.discounttiredirect.com/di...=Car%2FMinivan
Old Feb 20, 2012 | 12:14 AM
pizzato16's Avatar
pizzato16
take to a discount tire if you got one. Theyll check it out for free an fix any leak for free.
Old Feb 20, 2012 | 02:57 AM
The probability that you have 4 tires leaking at the same time is about 1000 to 1:
a. Installer used ill-fitting valve stems.
b. Tire size inappropriate and does not seat properly.
Old Feb 20, 2012 | 07:41 AM
briin79's Avatar
briin79
+1 yup what he said
Old Feb 20, 2012 | 08:08 AM
terrasmak's Avatar
The car is rejecting the crappy wheels. WHAT WERE YOU THINKING?
Old Feb 20, 2012 | 08:14 AM
zerostyle's Avatar
zerostyle
Its not tire size...you cant put a 16 or 18 tire on a 17 rim. 16 wont go on without shredding the thing completely. And then it wouldnt hold air at all. 18 would fit right over and you cant even get the bead to sit. Only thing would be half size tires aka like a 19.5 but those are usually trailer tires so thats all rule out....if its all four my money is on tpms.
-either valve core wasnt properly tightened
-the nut wasnt properly tightened or maybe over tightened and cracked the metal stem area
-the grommets are probably corroded and old and now wont seal
Get a bottle of spray, something that bubbles and spray it over your sensor. Just take it DT and get some rebuild kits. They are cheap and SHOULD be done EVERY time your taking a tire off and on. At least its what i recommend! I gave DT two years so trust me!
Old Feb 20, 2012 | 10:23 AM
R350Zz33's Avatar
R350Zz33
Wait so why did you downgrade ?
Old Feb 20, 2012 | 10:26 AM
Guilty1s's Avatar
Guilty1s
Why you downgrade?
Some wheels arent TPMS compatable. They might not have enough room to seat the whole thing in there comfortably without pressure on something.
Old Feb 20, 2012 | 10:36 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
+1
Rebuild kits are inexpensive.
Old Feb 21, 2012 | 10:01 AM
neal@tirerack's Avatar
neal@tirerack
I would guess the rubber gaskets on the sensors. We sell the rebuild kits if you need them, just let me know.
Old Feb 21, 2012 | 10:17 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
I think what DavidV meant was the WIDTH being incorrect. AKA super stretched tires.
Regardless, I'm betting it's the TPMS as well.
Old Feb 21, 2012 | 10:52 AM
Correct. We have members going with stupid stretch and fat tires. Extreme sizes may not seal properly.
Old Feb 21, 2012 | 11:06 AM
BoomerZ33's Avatar
BoomerZ33
if you really like the rims get the rebuild kit that tirerack is offering you. but check first to make sure the air leak isn't coming from anywhere else like the valvestems.
Old Feb 21, 2012 | 12:23 PM
Vivid Racing
Vivid Racing
brb, putting a 195/60 on an 18x12 -34 TE37SL. Next up is 325/30 on a 15x7.
Old Feb 26, 2012 | 07:34 PM
7 days and no followup. This is the new my350Z.com norm. Dead end gonnaget threads. Please help with no followup.
Old Feb 26, 2012 | 09:13 PM
Italianjoe1's Avatar
Italianjoe1
Only time I've seen this happen was on shitty rims with bad chrome and cheap no-name tires, they were all leaking around the beads. If you bought some made in indonesia tires with the DOT numbers cut out, then odds are you just need to buy some real rubber.
Old Feb 29, 2012 | 01:31 AM
paulmess7's Avatar
paulmess7
I've just been adding air every 3-4 days. Waiting for pay day so I can order some new tires, and with them I'll get the rebuild kits.
Old Feb 29, 2012 | 03:24 AM
122554's Avatar
122554
Or you could get the strap kits here:
http://www.revolutionsupply.com/TPMSIndex.aspx
That's how I had to mount the TPMS sensors on SSR wheels.
Obadabot
Jun 18, 2023 11:31 PM
