2003 Top End Engine Noise (Video link)
Old Feb 24, 2012 | 10:22 PM
saladito6's Avatar
saladito6
Default 2003 Top End Engine Noise (Video link)
Hi Everyone,
http://www.youtube.com/watch?v=inWM6...ature=youtu.be
I have a 2003 Enthusiast that I've had since 2004 and recently I have heard a loud clicking/ticking coming from the top end of my engine. The engine has 110K miles on it and the video was taken after I changed the oil and ran the car. The noise frequency increases as the engine is accelerated. I haven't seen any dramatic drop-off in performance. I am hoping there is another thread addressing this issue that I couldn't find or if searching to see if anyone had an idea or answer to what this noise is.
Also I am located in San Diego, CA and would appreciate if any one could refer me to a good mechanic with a lot of 350z experience who could diagnose my engine problem if it can't be solved in this forum or if they can help me themselves.
FYI. I have been on this site for a while and I tried searching for a similar situation, but the subjective nature of the engine noise description in the search function makes it difficult to find the same exact symptoms that I have.
Thank you everyone for your help
J.T.
Old Feb 25, 2012 | 03:10 AM
JCITY's Avatar
JCITY
Its hard to specifically tell from your video.But what it sounded like to me was typical lifter/valve noise.What kind of oil are you using?Does your car use any oil between changes?
You may want to flush the engine with Marvel Mystery Oil(or a equivilent).Possible a heavier weight oil(10-30)&a additive to quiet the noise.
See what happens.
Old Feb 25, 2012 | 04:32 AM
Fitzys350z's Avatar
Fitzys350z
Those could also be your fuel injectors. there quite noisey too. sounds pretty normal to me.
Old Feb 25, 2012 | 04:33 AM
jerseystyle's Avatar
jerseystyle
*Moved
Old Feb 25, 2012 | 09:26 AM
saladito6's Avatar
saladito6
JCity- I have always used Mobil 1. I do see that there is oil consumption. I have switched to 10w-30. Do you know of any additives that I could use in the mean time besides the engine flush you recommended? I just changed the oil.
Fitzys350z- Is there a known problem with 350z's where the fuel injectors just start to get loud? My car sounds like a diesel engine.
Thanks guys.
Old Feb 26, 2012 | 09:17 PM
saladito6's Avatar
saladito6
Any links to other who may have had the same problem or like symptoms?
Old Mar 7, 2012 | 10:47 AM
saladito6's Avatar
saladito6
For closure sake, I just got a diagnosis from a Nissan Mechanic and they said its probably a loose rod ($2500-$4500 for repair). They said it could be driven on for a short time period, but looks like i gota get a new car. It sucks because Ihave babied this car, but you never know whats going to happen after the warranty runs out. I will be parting out the after market things shortly including: Brembo brakes, '06 OEM LED lights, sub box etc.
Siqcology
Sep 18, 2019 01:45 PM
cashmoney03
Sep 27, 2015 05:24 PM
ti837
Sep 22, 2015 07:46 AM
FromGtoZ
Sep 20, 2015 03:41 PM
RWDBajan
Sep 8, 2015 06:25 AM
