Help STRONG vibration while driving
Old Mar 5, 2012 | 07:57 AM
91180sr's Avatar
91180sr
Default Help STRONG vibration while driving
OK, So I was driving my 04 z yesterday and I got on it in 1st pulling out of a parking lot, spund the tires got a tad sidewards then a massive vibration started and i pushed the clutch in right away. pulle dover and it was in the shifter like crazy so its the driveline. I shut it down looked around nothing seemd messed up or leaking. I started it back up seemd ok slight vibration in shifter. goes into all gears ok, motor sounds healthy still, I pull out and anything over 2500rpms the vibrations are back but get bad over 3500... SOOOOOO i will inspect today after work but was wondering if anyone had any ideas? Also i had a slightly bad right motor mount i was going to replace could that be it? or trans mount?
any good input would be nice thanks!
Alex
Old Mar 5, 2012 | 10:02 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
So you get this nasty vibration while the car is not moving? If so, check all of your subframe and differential bushings.
Edit: Just read the part about the engine mounts. Yes, that could be it. Check subframe/diff mounts, and engine/trans mounts.
Old Mar 5, 2012 | 10:09 AM
91180sr's Avatar
91180sr
Thanks for reply, yeah I'll check them all today Hopeing it's something easy.
Old Mar 6, 2012 | 03:35 AM
Shizzmaster2k's Avatar
Shizzmaster2k
So what's the verdict?
Old Mar 9, 2012 | 11:49 AM
91180sr's Avatar
91180sr
Well, my diff bushing was cracked ad clearly been bad for a while. And when I put the rear end up as drove threw 1st and 2nd not so much vibration or noise . So I ordered spl solid diff bushing kit. It comes tomorrow ! I'll see if that it . Also I'll replace the weaker motor mount. Even tho that's not completely broken
Old Mar 12, 2012 | 05:50 AM
91180sr's Avatar
91180sr
So spent a few hours yesterday and installed spl solid rear diff bushing kit! Nice stuff . Except that was not the issue they were blown but it the cause of my issue ..... Its when I reallllyyy get on it just terrible noise and vibrations! Fml , I don't think it's any mounts I have a feelin it's my shitty oem flywheel ? Only Beause it's been so noisy for ever . I figured it's messed up? But would it drive ?
Old Mar 14, 2012 | 05:43 AM
91180sr's Avatar
91180sr
What else? This sucks
Old Aug 20, 2012 | 11:54 AM
z32-z33's Avatar
z32-z33
I know this thread is a few months old but is there an answer to the problem? I'm having the same problem.
Old Aug 22, 2012 | 07:49 PM
z32-z33's Avatar
z32-z33
Bump!! Anyone else know what could be wrong? Need help please!!
Old Aug 24, 2012 | 04:58 PM
Itzcashew's Avatar
Itzcashew
When was the last time the clutch and fw was.replaced
Old Aug 27, 2012 | 07:07 PM
z32-z33's Avatar
z32-z33
Its never been replaced. Has about 115,000 on the original clutch and flywheel.
Old Aug 27, 2012 | 07:14 PM
Nismo44512's Avatar
Nismo44512
I'm noo mechanic, but I'd say it's time to replace the clutch and flywheel haha.
Just my $.02
Old Aug 29, 2012 | 08:06 AM
z32-z33's Avatar
z32-z33
The clutch and flywheel will be replaced sometime this week or next week, depending on when my new clutch disk comes in. I really hope this fixes it.
Old Sep 2, 2012 | 11:07 PM
z32-z33's Avatar
z32-z33
Update. I just finished installing my jwt clutch and flywheel and this totally fixed the problem.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
