Wheel bearing issue! Please help
Old Mar 27, 2012 | 12:54 PM
JmNismo's Avatar
JmNismo
Default Wheel bearing issue! Please help
Ok to make a long story short, about 6 months ago I noticed the infamous wind tunnel noise coming from my passenger rear wheel not to mention the rear-end felt a little sloppy while driving... So I figure/diagnose the problem as the wheel bearing... No biggie, I'll change out the wheel bearing and go on my way.. The problem is when I did change it about 5 months ago, the bearing went out once more, I replaced it once again, and about 4 weeks ago I changed it for the 3rd time!! And to make problems worse I'm starting to feel and hear that its going out again!!!!!!!!!!! What could possibly causing it to go out???
Cliff notes: Wheel bearing keeps going out ever 1-2 months or so.. needing to know what could possibly be the cause! Any help or ideas would help!
Old Mar 27, 2012 | 01:16 PM
bmccann101's Avatar
bmccann101
hella weird.. i run a 50 mm spacer and even my bearings only went once in their lifetime.
id submit that its incorrect installation.. thats the only constant.. ill let someone more experienced reply, but thatd be my guess.
Old Mar 27, 2012 | 01:44 PM
JmNismo's Avatar
JmNismo
I havent changed the hub.. Just the bearing each time.. could the hub be bent maybe or something lol?
Old Mar 27, 2012 | 02:18 PM
terrasmak's Avatar
Change the hub, the like to die with the bearing. Ive lost two bearing and one hub. Also the bearing is weak, my last one went out in a high speed slide at Willow springs. Ive also gone offroading at high speed with out a problem. Luck of the draw.
Old Mar 27, 2012 | 02:34 PM
JmNismo's Avatar
JmNismo
Could bad suspension or anything like that, cause them to go out?
Old Mar 27, 2012 | 06:06 PM
TURBOROADSTER's Avatar
TURBOROADSTER
Autozone Chinese bearings ?????
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
