CEL P1273? need some help
Old Mar 27, 2012 | 07:26 PM
Bmurray350z's Avatar
Bmurray350z
Default CEL P1273? need some help
Well today my car threw a check engine light, so i went and got it scanned and it was only 1 code (P1273)
P1273 NISSAN - Air Fuel Ratio (A/F) Sensor 1 Lean Shift Monitoring Bank 1
I recently got my car tuned.. and everything was perfect. could this just be that I need a new air fuel sensor?
2004 350z enthusiast
93 octane - always
synthetic fuel - always
mods:
injen intake
md spacer
headers, tp, true dual exhaust..
any advice? tips?
Old Mar 28, 2012 | 11:07 AM
Neimad's Avatar
Neimad
You've basically taken it's whole reason for existence (converters) out of the loop. Even if it is bad you don't need it much anymore. Double check for vacuum leaks/exhaust leaks on B1 (passenger), only mechanical issue likely for it to be detecting.
Old Mar 28, 2012 | 05:50 PM
Bmurray350z
yeah. i called the shop that tuned it and they said they can just take it off with the uprev software and it won't come back.
but on another note, i came across this today. could this just have been bad gas? please watch the video:
http://www.youtube.com/watch?v=SQSOV37XSQM
Old Mar 28, 2012 | 06:03 PM
Neimad's Avatar
Neimad
That was painful to watch, maybe bad gas, real easy to test gas for water/alcohol if you have tools to obtain sample from fuel rail. I'm surpised that z wasnt flashing MIL for imminent converter fire.
Old Mar 28, 2012 | 06:13 PM
Bmurray350z
im hoping its bad gas. or at least nothing to bad. it runs fine now. which is really weird.
Old Mar 28, 2012 | 06:23 PM
Neimad's Avatar
Neimad
Don't worry about it. There were no driveability problems right?
Old Mar 28, 2012 | 06:30 PM
Bmurray350z
nope, none at all. just happens once in a blue moon
Old Mar 28, 2012 | 07:59 PM
Neimad's Avatar
Neimad
Solid check engine is mainly there to warn of potential loss of ECM's ability to maintain emissions levels within 1.5 times the federally mandated emissions levels. Flashing means worse and potential catalyst fire. Performance and emissions output don't go hand in hand after a point. Check the codes as they pop up incase something more important goes. You have a free range VQ now, enjoy it. I wonder if the Uprev tuning at least uses the A/F calculation from the O2 signal to achieve optimum injector pulse width or just runs as rich as possible for MAF/TCS etc calcs?
http://en.wikipedia.org/wiki/Oxygen_sensor - Bosch rules the world but no one knows it
Old Mar 29, 2012 | 01:12 PM
espadinha4's Avatar
espadinha4
i had codes popping up recently. can someone tell me where i can buy the sensors
Old Apr 20, 2012 | 08:43 PM
Bmurray350z
can anyone else chime in. its still happening. watch the video if you haven't yet
Old Apr 22, 2012 | 07:31 PM
Bmurray350z
bump
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
Bigsyke
Sep 11, 2015 06:19 PM
Darkspy
Sep 7, 2015 09:09 PM
guido51
Mar 31, 2005 06:26 PM
