Passenger Side Window Noise
So I have an 03' Base and lately I have been hearing some rattling noise coming from the PS window. If I roll down the window a little the noise is gone completely. How hard is it to take the door panel off these cars?
The door panels aren't difficult to remove at all. I get the rattling noise when the window is down all the way and rolling it up slightly resolves it.
Removing the passenger side door panel if it's the same as 06:
*Using a flathead screwdriver and a cloth or paper towel, pry off the silver cover on the handle itself...I believe you start on the bottom.
*remove the two bolts behind that cover
*use a panel tool, screwdriver, or your fingers, pop off all of the fasteners holding it on.
...I just realized without doing it myself, this is all I remember, lol.
Cool. I will be checking that out on the weekend. The noise I get is when the window is rolled up all the way, or all the way down. Any where in between and there is no noise. I just it is as ez as my FC door panel. that was only like 4-6 screws. Again thanks!
CFAUVEL
Oct 1, 2015 03:20 PM
