Help. loud engine rattle noise
Old Mar 28, 2012 | 03:09 PM
bkjmr's Avatar
bkjmr
Default Help. loud engine rattle noise
My car seems to be making this noise. Well its similar to this but I don't have any whining. Well I don't think i do.
Engine Noise
I can get a video of my actual car tomorrow if that would make it better?
I was told by the recovery man that it could be the bottom end that's gone.
Reading up a bit more as I was writing this it sounds a lot like a loose flywheel. I did have a fidanza lightweight single mass flywheel and exeddy clutch installed about 2 months ago.
All help will be appreciated. I'm from the UK so I will probably not read any replies, if there are any, till the morning.
I would also like to add there is no check engine light on.
The day the noise began the car stalled at the lights then when I pulled off and pulled over I heard the noise. I then took it to get fuel where it stalled again once i started it. It didn't stall when I pulled over prior to getting petrol. Them mid way through driving the car cut out and wouldn't start. I was only hearing a single clicking noise. I left it for about 20 minutes then it started but it was making the horrible rattle noise still.
I have been searching but I thought I would make a post as I didn't find much. Also sorry if its in the wrong section. I'm very new to the forum and not too sure where it should be.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
