Weird noise on the front suspension
Old Apr 3, 2012 | 05:25 AM
Angel55's Avatar
Angel55
Default Weird noise on the front suspension
I have purchased a 08 z at the summer with almost 20k miles. So far i enjoyed the z. But recently, i began to experience a loud noise.
The noise occurs ONLY when im in bumpy roads whether its ruff or soft located at the front passenger side on the bottom. The noise does NOT occur when i turn my steerin wheel only when i hit several bumps and pot holes.
I could not find any threads with problems that i experienced and was hoping for some sugguestion on fixing my noise problem.
Old Apr 3, 2012 | 07:30 AM
bmccann101's Avatar
bmccann101
so.. whats the noise? you kind of left that out man.
Old Apr 3, 2012 | 07:38 AM
Angel55's Avatar
Angel55
My fault. Its kind of hard to explain but its definetly not a squeeky noise of a sway link. I would say a rusty sound even though I do not see anying rusty on the front right suspension. Or maybe a bed spring sound. Such as when you have sex in an old bed and you hear the spring noise. Maybe something like that.
Old Apr 3, 2012 | 07:42 AM
white boy's Avatar
white boy
what u described could be 100 different things. hard to tell when ur on PC
Old Apr 3, 2012 | 07:47 AM
Angel55's Avatar
Angel55
Exactly, I would try to make a video but i do not think the video would catch the noise. Ill try it later today after school.
Old Apr 3, 2012 | 08:16 AM
terrasmak's Avatar
First two major things that could easily be wrong. Sway bar end link or lower control ARM bushing.
Old Apr 3, 2012 | 08:23 AM
Angel55's Avatar
Angel55
Definately not sway bar endlink since I had an tb that had swaybar link noises that do not sound what I am experiencing.
Lower control Arm bushing? What are the symtops or sounds of a bad lower control arm bushing? I have read several threads talking about a loose bolt somewhere in the suspension area...
Old Apr 3, 2012 | 02:28 PM
Angel55's Avatar
Angel55
Hm i cant even attach a music file into the forum. Does anyone know how to insert a m4p music file (iphone 4 voice memo app) into forums?
Old Apr 3, 2012 | 10:40 PM
DSLisFREE's Avatar
DSLisFREE
http://www.*********.com/wiki/index....ont_Suspension
"350z hyphen tech" goes into the ****
See if that helps. In addition:
https://my350z.com/forum/maintenance...front-end.html
Old Apr 4, 2012 | 05:46 AM
Angel55's Avatar
Angel55
The link does not work with the 350z hyphen tech replacing ******
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
