Really need some Z guru help :(
Old Apr 29, 2012 | 05:11 PM
jlasiter's Avatar
jlasiter
Default Really need some Z guru help :(
here is my story 03 350z manual touring- note that this does not happen all the time but when i take my car out and floor it it will hit about 5000rpm and just loose all power cutting out and make the car jerky ( only when i floor it, if i just let the rpms ride up to 5000 no problem) this happened again last night and this time when it happened i didnt let off i tried to keep pushing it hoping it would either clear its self or set a code but that was not the case car just shut right off/died i pulled over and started it again
also a few weeks ago i had another problem where as soon as i started the car it would start up then die after 3-5 sec not sure if its related but could be
i have no codes being set no slip light or any thing, i tried cleaning the MAF to see if it would help but no luck
where do i turn from here ?
Thanks in advance!
Old Apr 29, 2012 | 06:11 PM
R350Zz33's Avatar
R350Zz33
For info on the car. Mods milage recent things you changed ext.... We don't work magic with no info
Old Apr 29, 2012 | 06:14 PM
Bmurray350z's Avatar
Bmurray350z
are these episodes of your car losing power - during the rain or after you wash you car by anychance? do you have a cold air intake?
Old Apr 29, 2012 | 06:32 PM
bmccann101's Avatar
bmccann101
almost sounds like the ebay led taillight syndrome. U know, the one ppl think is not real haha..totally is tho.
Old Apr 29, 2012 | 07:02 PM
jlasiter's Avatar
jlasiter
03 with 116,000 i did the clutch over the winter thats about it, yes i do have CIA and i did happen to was my car last night but drove for 2 hours before it happened but i think it has happened with no rain or wash
and its kinda feels like running out of gas that big chug you get and then pick up a bit of gas then chug again i tried to get a video today but could not get it to happen
Old Apr 29, 2012 | 07:13 PM
Bmurray350z
oh just wondering. because a couple times after i've washed my car i'll get on it and it will lose power for like half a second at 3500 - 4000 rpms, then jerk and gain power again. kinda weird but apparently it was just some water that got into the filter..
Old Apr 29, 2012 | 07:21 PM
RMichael's Avatar
RMichael
mmmm, Canada.
Old Apr 29, 2012 | 07:38 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Apr 29, 2012 | 08:18 PM
R350Zz33's Avatar
R350Zz33
try an ecu reset
Old Apr 29, 2012 | 09:08 PM
drifter5's Avatar
drifter5
Could be a camshaft position sensor, 03s are notorious for that issue. My guess would be that especially if with that many miles on the car and never had to replace it.
Old Apr 30, 2012 | 05:02 AM
jlasiter's Avatar
jlasiter
i did do an ECU reset about 2 weeks ago that seemed to help with the car dying on start up,
i will look into the Cam position sensor
Sk8fe
Mar 26, 2006 11:06 AM
GodZilla
Photoshop
Dec 16, 2005 02:45 PM
Sexy350zStud03
Cleaning & Detailing
Oct 13, 2005 04:18 AM
