PLEASE HELP ME!! My Z is Dead!!
Old May 1, 2012 | 02:38 PM
xslangx's Avatar
xslangx
Exclamation PLEASE HELP ME!! My Z is Dead!!
I just cleaned the throttle bodies and now the car is going CRAZY
the idle revs all the way to 2000 then drops to 1500 and up to 2000 and drops to 1500 and doesnt stop!!!
If I turn the AC on FULLL BLAST it kinda stops it but second i turn it off it goes away!
WTF!!!
Please help me... I tryed to throttle body reset or w/e and its not working
I have work in 30 minutes and im ****ed!!
Old May 1, 2012 | 02:40 PM
LuciaPwNs's Avatar
LuciaPwNs
i'm thinking you need to do the throttle calibration process. i believe we have those.
edit-didn't read whole thing. id make sure you are doing it right.
Old May 1, 2012 | 02:42 PM
xslangx's Avatar
xslangx
I tryed it like 6 times and its not working!!!
I cleaned a few hoses here and there but nothign major!!
Its totally revving up and then stumbling to 1500 and revving up then stumbling
Ive tryed leaving the battery unplugged like EVERYTHING!!
i pinned the TB's open while cleaning them did I ruin it??
Old May 1, 2012 | 02:48 PM
xslangx's Avatar
xslangx
Please anyone??
Old May 1, 2012 | 02:52 PM
ocdz's Avatar
ocdz
You're not supposed to move the throttle plate when you clean them. You may have ruined your TB. What kind of noise does it make when you turn the key to On but do not start?
Sounds like it's running, thats means its not dead.
Old May 1, 2012 | 02:58 PM
Frosty87's Avatar
Frosty87
Is ur maf in securely it could cause limp mode
Old May 1, 2012 | 03:03 PM
xslangx's Avatar
xslangx
how the hell can you clean a TB without moving them? makes no sense
im stuck Ive reset the battery and everything
IDLE steadies with AC on hasnt anyone had this problem before?
Old May 1, 2012 | 07:26 PM
350z006's Avatar
350z006
Do you have a CEL light on your dashboard?
Old May 1, 2012 | 07:51 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Yup. It may not be good news for you.
But just in case:
If you've done the relearn, have you also checked to make sure that you remembered to reconnect all sensor connections and the vacuum line underneath the intake tubes?
Old May 1, 2012 | 09:19 PM
Dallasmavs92's Avatar
Dallasmavs92
With electronic tb's you gotta be careful. Manual ones move em all you want. Very fragile motors in these.
Old May 2, 2012 | 11:20 AM
xslangx's Avatar
xslangx
I have NO CEL, just a idle that constantly goes from 1500 to 2000 then back down to 1500 then up to 2000 it just CONSTANTLY does it
like VROOOOOOOOOOOOmmmmmmmmmmVROOOOOOOOOOOOOOmmmmmm
Old May 2, 2012 | 11:22 AM
350z006's Avatar
350z006
Could be a god-awful vacum leak...
Old May 3, 2012 | 01:48 PM
xslangx's Avatar
xslangx
I haz CEL now..
Old May 3, 2012 | 02:18 PM
KornerCarver's Avatar
KornerCarver
Maybe you should take your car to a mechanic.........
Old May 3, 2012 | 02:21 PM
xslangx's Avatar
xslangx
I took it to nissan, they tryed to do a hard reset of the TB's and relearning procedure...
they said they are both dead and require 2 new throttle bodies..
THE FUKKK
Old May 3, 2012 | 02:28 PM
*ICE*'s Avatar
*ICE*
search on ebay for new TB.. you probably mess up the sensor inside it while cleaning.
Depravity
Oct 1, 2015 04:49 PM
MustGoFastR
Mar 11, 2003 06:04 PM
Shogun
South West
Mar 11, 2003 01:45 PM
PhoenixINX
Oct 31, 2002 08:15 AM
