Hatch Lift Spring Substitute
Hey guys I need new hatch lift springs...these are the silver rubber spring things in the pic below...they're black stock, I guess this guy painted his.
Before I spend $30+ for each of these things I'd rather see if I can use some kind of cheaper spring alternative from somewhere like home depot, lowes, walmart, hardware store, auto parts store.
Do you guys have any ideas?
cuz I they weren't on the car when I got it...you have any ideas for substitute? I figure its about 2-3 inches tall with a 1'' or 1.5'' diameter...but the only springs I've found in this range are really thin...I need thicker ones with more strength
Maybe I use a few on each side...any ideas?
That's a flash picture, they're just regular black rubber.
So, your car is currently completely missing that entire assembly?
I would go for *any* wrecking yard first - otherwise, suck it up and get the replacements. There is a quickfix of shoving some quarters inside the rubber boot if they're not strong enough.
incorrect.
They are a spring covered in a black rubber boot and are what pops the trunk lid up when the latch is released.
They are 30 dollars each from courtesy nissan or West Covina nissan.
Please buy the correct items to upkeep your car.. making your own is completely silly.. jsut live without them if you can afford the replacement costs.
Search my thread on putting rubber shims between the coils of the springs.
Easy,cheap,works.There is a pic of this assembly/mod in my veh. pics.
Alright thanks...I've got a much bigger problem to handle first...I need to replace the 4 lower control arms for the front suspension and two sway bar links..I'm gonna search around for how-to's and advice for this
350Z_Al
Oct 29, 2020 07:44 PM
