2003 Z High-Pitched noise when accelerating
Old May 12, 2012 | 03:24 PM
ZDominicZ's Avatar
ZDominicZ
Default 2003 Z High-Pitched noise when accelerating
I just bought a 2003 350z base with 86,000 miles and have a high-pitched noise only upon acceleration. I can hear it in all gears and in neutral when I'm stopped. Could this be a vacuum leak or...? I'd appreciate any help. thanks
Old May 12, 2012 | 05:02 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Is there any way you could record it on video (or at least audio)?
Does it sound like a whistling noise? My pop charger intake whistles pretty loudly when at 50-75% throttle regardless of RPM.
Without a better description than "high-pitched noise", its going to be hard for me to do any better than that.
Old May 12, 2012 | 05:54 PM
Is it kind of like a
weeeeeeeeeeeeeee
or more like a
whirleeeeeeeeeeeeeeeeeeee?
Old May 12, 2012 | 07:49 PM
bmccann101's Avatar
bmccann101
vacuum leak, usually on the plenum, espec if its aftermarket.. car idling... spray some carb cleaner around the plenum.. if theres ANY change in RPM, its a vacuum leak.. my Kinetix V composite plenum did this in the hot summers.. it was LOOOOUD.
Old May 12, 2012 | 09:49 PM
ZDominicZ's Avatar
ZDominicZ
the car is all stock, I tried to get a video of it but it wouldn't come out. I'm thinking its a vacuum leak. I'll tear it apart tomorrow and let you guys know. any ideas on which tubes to check first?
Old May 12, 2012 | 10:23 PM
SparkleCityHop
Living in 350Z
The easiest one to miss is the one that attaches to the bottom of the intake tube. Very common mistake.
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
