Problem with front wheel
Old May 31, 2012 | 05:09 AM
celiboom's Avatar
celiboom
Default Problem with front wheel
Hi! yesterday, as I was changing my tires, I noticed that once the car is jacked, I can grab the front passenger wheel from side to side and there is a little play when I apply some pressure. there is no play when grabbing the wheel top and bottom. I've checked my driver side front wheel and everything is good, nothing moves.
what can cause this? bearing? tie rod?
Everything is normal when I drive but I guess that the wheel is wobbling a little?
Thanks
Old May 31, 2012 | 05:20 AM
Bret86944's Avatar
Bret86944
It's probably a wheel bearing.
Old May 31, 2012 | 07:12 AM
celiboom's Avatar
celiboom
exactly what I was thinking but I don't have that "wobbling" sound while turning the stearing
Old May 31, 2012 | 07:46 AM
dcains's Avatar
dcains
I'd guess tie rod ends. If it was the bearing wouldn't it be loose in all planes?
Old May 31, 2012 | 07:50 AM
celiboom's Avatar
celiboom
Is there a way to test if it's my tie rod end?
Old May 31, 2012 | 07:53 AM
dcains's Avatar
dcains
Put the car on an alignment rack. Or, I suppose you could have your hand on the rod end while someone else shakes the wheel, and see if you can feel the source of the free play. Do you see any unusual wear on the front tires?
Old May 31, 2012 | 01:27 PM
tony530's Avatar
tony530
Wheel bearing....toe rod just grap it and pull it or with pillers. If u have doubts just pull the other side side if it reacts the same. If not then it ur wheeling bearing.....
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
