Upgraded to Xenons, engine problems!!??
Old Jun 1, 2012 | 05:34 PM
Teha99's Avatar
Teha99
Default Upgraded to Xenons, engine problems!!??
Hey guys I just installed my 08 headlights today. I cut the harness from my old light and just connected the wires and everything works great. The problem is, when I turn on the headlights, the engine shuts off a few seconds later... It's not the engine but something electrical because I see the revs slowly going down. The lights also do not power up all the way so the beam is blue instead of white.
Any suggestions? My service engine soon light also came on
Old Jun 1, 2012 | 06:20 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
So you did not have factory HIDs before the install?
Old Jun 1, 2012 | 06:23 PM
Teha99's Avatar
Teha99
Nope... Im thinking it might be a fuse issue since the car is not used to pulling that much power for the headlights?
Old Jun 1, 2012 | 06:30 PM
myork's Avatar
myork
HIDs use less power - you wired something wrong. What exactly did you do?
Old Jun 1, 2012 | 06:46 PM
Teha99's Avatar
Teha99
So I cut off the 8pin connector off the 06 headlight and wired in a 6pin connector that I took off of my 05 lights. I matched the colors because online DIY's showed the diagram and colors matching. Everything works fine, I dont have the constant blinker and they work as signals and hazards. DRLs work, and low beam and high beam work fine.
Old Jun 1, 2012 | 07:39 PM
myork's Avatar
myork
Well I found a guide on another website and it said you have to swap a 20 amp fuse to replace your existing one, so evidently the HIDs for the Z are more power hungry.
Never heard that before, most HIDs are 35 watt.
Also, those DRLs arent really supposed to be there, you need to pull the blue wire out.
Here is the link:
http://www. 3 5 0 z m o t o r i n g.com/forums/diy-garage/40931-how-install-2006-hid-lights-base-z.html
Old Jun 1, 2012 | 08:06 PM
Teha99's Avatar
Teha99
The DRLs are the parking light that runs with the first flick of the Headlight setting.
I saw that post about the 20A fuse too... But no one else has ever said that before...
I might just have to try it.
Old Jun 2, 2012 | 02:54 PM
Teha99's Avatar
Teha99
So the problem is that the lights are taking power. If I turn them on with the engine on, it messes up the throttle position sensor. Alternator and battery checkout, but pretty much the lights are robbing power from the engine.
I need the car to produce more electrical power... any suggestions?
Old Jun 2, 2012 | 04:47 PM
Netko350Z's Avatar
Netko350Z
[quote=Teha99;9760139]So the problem is that the lights are taking power. If I turn them on with the engine on, it messes up the throttle position sensor. Alternator and battery checkout, but pretty much the lights are robbing power from the engine.
I need the car to produce more electrical power... any suggestions?[/quote]
Old Jun 2, 2012 | 06:11 PM
KornerCarver's Avatar
KornerCarver
Trust me............the HID lights take less power to run than the halogen lights. You have wired something incorrectly.
Old Jun 2, 2012 | 06:15 PM
mr. sparco's Avatar
mr. sparco
Definitely wiring error, I have an 05 with 06 headlights no issues. One of the wires is not used for the 05.
Old Jun 2, 2012 | 07:59 PM
Teha99's Avatar
Teha99
I am definitely sure its not a wiring issue. Everything works great... parking lights, blinkers, and low and high beams. It just sucks the power...
Mr. Sparco did you have an 05 Base model? would you be able to post a picture of it connected?
Thanks,
Teja
Old Jun 2, 2012 | 08:27 PM
mr. sparco's Avatar
mr. sparco
If you wired it up correctly, you shouldn't be having issues. I have an 05 base and did the swap back in 06, this is all I could find.
Old Jun 2, 2012 | 09:19 PM
Teha99's Avatar
Teha99
I followed your diagram. The first picture is the 8pin looking at the opening right?
The second 6pin diagram is the view from behind the connector (the way the wires go into the pins rather than the pins themselves rite?)
If above is right, then all of my wires match up perfectly.
I will try and replace the dead battery... might help.
Old Jun 3, 2012 | 08:44 AM
mr. sparco's Avatar
mr. sparco
I don't remember it's been almost 7 years. I drew that on my knee while soldering.
Old Jun 3, 2012 | 09:00 AM
Teha99's Avatar
Teha99
wiring definitely checks out with other diagrams too. This is getting very frustrating. I rewired everything again and still the problem persists. It may be my dead battery.
Old Jun 3, 2012 | 10:52 AM
mr. sparco's Avatar
mr. sparco
Dead batteries are no good.
Old Jun 3, 2012 | 08:52 PM
Teha99's Avatar
Teha99
Whew! Got it working!
I decided I should just go back to the basics and try wiring up a relay... So I bought a 35A relay and some wires at pepboys and now the ballasts run straight from the battery. The ballasts now easily ignite without messing with the TPS and shutting the engine down
Uriyo_
Sep 8, 2021 08:46 AM
