Steering vibrations?. Help please!!!!!!!
Jun 8, 2012 | 11:08 AM
Hey I have a 2003 track 350 and was wondering if maybe someone could help. Well I purchased a set of performance 18" rims and put them on. Well all of a sudden my car starts vibrating and if feels like its coming from my front tires. I'm running 245/40/18s when stock is 225/45/18. It's only vibrates when my steering wheel is straight or to the right. But if I make it the slightest bit to the left it stops... Help please!!!
Jun 8, 2012 | 11:18 AM
Senior Super Moderator MY350Z.COM
Are your new performance reems hubcentric to the Z?
Jun 8, 2012 | 11:43 AM
I put on my old rims and it did the same thing... So it's not the rims. Something with the car
Jun 8, 2012 | 12:30 PM
Checked alignment and all the bushings?
Jun 8, 2012 | 12:36 PM
when this happened to me it was my tread separating from the tires, but since you put different wheels with hopefully different tires on I am guessing that is not the problem
Jun 8, 2012 | 12:47 PM
Yeah complete diferent rims... brought it to les schwab and the guy said nothing looks outta ordinary.. havent checked bushings but I know my alignment is alittle off. That wouldnt make it vibrate going a certain dirrection tho would it?
Jun 8, 2012 | 01:08 PM
Turns out my left front wheel bearing is going out and maybe my hub is bad...
Jun 8, 2012 | 01:09 PM
If you buy new wheels, and the problem begins that day, then the wheels are the culprit. The wheels are OK its the balancing that is at fault.
Jun 8, 2012 | 01:33 PM
Quote:
Originally Posted by
defragged1
Hub and bearing are not seperate up front, also very easy to swap.
Jun 8, 2012 | 01:36 PM
Any recommendations for the hub. Also I figured I might as well replace the rotors with drilled and slotted..
Jun 8, 2012 | 01:44 PM
defragged1
OEM, and blank rotors are best
Jun 8, 2012 | 03:12 PM
I agree. I went stop-tech slotted rotors on mine. Not as good as the OE.
Jun 8, 2012 | 04:02 PM
Arvin89
I wouldn't get OEM, I would go centric blanks
Jun 8, 2012 | 04:46 PM
This was my initial thought. Luckily OP found the issue.
Jun 8, 2012 | 05:02 PM
Thanks guys that helps, keep posting if you have more to say regaurding rotors. Or anything I guess lol
Jun 11, 2012 | 07:59 AM
Would there be much difference between aftermarket blanks, and the oe replacement? I had assumed it would be minimal.
Jun 11, 2012 | 09:49 AM
Arvin89
OEM rotors are make from silly puddy and cost a bit more.
aarrgghh
May 1, 2022 11:04 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
CFAUVEL
Oct 1, 2015 03:20 PM
dragon11689
Sep 7, 2015 02:47 PM
