cyl 5 misfire and high idle vq35hr
Old Jun 9, 2012 | 05:40 PM
limetme's Avatar
limetme
Default cyl 5 misfire and high idle vq35hr
hi well this is my first post i hope its in the right section. anyways i just came from a vw r32 and bought my 07 350z 2 days ago, by the time i got home it had a check engine light. the code was for cylinder 5 misfire, noticed a high idle which it stay around 1000rpm and figured this was because of a lean condition causing the ecu to make it run rich? sometimes i start the car and the CEL is off and its back down to idling around 700? i pulled the intake today and im just so confused, maybe someone could help me with ideas.
the car is an 07 with the vq35hr and 56k miles
also one port is really clean?
Old Jun 9, 2012 | 11:40 PM
dtowngreg's Avatar
dtowngreg
damn kinda makes me nervous. im buying an 07 from a guy i know. should get it next month. 51k miles and it has never been modded. with no warranty i cant afford that
Old Jun 10, 2012 | 03:48 PM
limetme's Avatar
limetme
how much are you suppose to be picking it up for? jw. but anyways it turned out to be the spark plug wasnt tight enough so it was blowing out of the sparkplug hole
Old Jun 10, 2012 | 11:02 PM
dtowngreg's Avatar
dtowngreg
well its got 1500 of audio into so a lil more than kbb value. and 19800
and good thats a relief
derekinthez
South East
Sep 28, 2015 06:35 PM
