my clutch is going bad, some help needed
Old Jun 26, 2012 | 08:18 PM
mike_350z's Avatar
mike_350z
Default 350zzz
sfd
Old Jun 26, 2012 | 08:28 PM
mattleegee's Avatar
mattleegee
that is a good dealer, its OEM
Old Jun 26, 2012 | 08:57 PM
mike_350z's Avatar
mike_350z
would u recomend to buy through this seller?
Old Jun 26, 2012 | 09:13 PM
mattleegee's Avatar
mattleegee
why not? its going to be cheaper then your local dealership
they have a website also if you prefer to order that way....
you can shop around the sponsors on the forum also that carry OEM replacement parts
it all comes out of your wallet, no way around it
Old Jun 26, 2012 | 09:22 PM
mike_350z's Avatar
mike_350z
i noticed this doesnt have a flywheel, will it make a huge difference if i change it or not
Old Jun 26, 2012 | 11:10 PM
BrickyardZ2003's Avatar
BrickyardZ2003
You'll want to resurface the flywheel to avoid chatter. Not sure how touchy these cars are, but on my old Mustang, I did a clutch swap without resurfacing or replacing the flywheel and had no issues. A machine shop will usually do the job for around $50.
Old Jun 26, 2012 | 11:23 PM
All that I have to go by is the description. The same description that you read.
Old Jun 27, 2012 | 08:33 AM
mike_350z's Avatar
mike_350z
Well I'm gonna get this kit except it doesn't have a flywheel so idk what to do
Old Jun 27, 2012 | 09:33 AM
musubi's Avatar
musubi
It's probably better if you replace your flywheel as well. It's not easy to find someone that will resurface the dual mass flywheel. Most will just tell you that you can't. OEM flywheels are about $1k, give or take a few hundred.
If you're going through the trouble, aftermarket equipment may be a way to go. It's cheaper too.
Old Jun 27, 2012 | 10:21 AM
BrickyardZ2003
Good catch, I completely forgot about the dual mass setup in the Z's.
Old Jun 27, 2012 | 03:36 PM
Josh|Swag's Avatar
Josh|Swag
I'd definitely just buy a brand new flywheel, you'll be glad you did in the long run.
Old Jul 1, 2012 | 05:35 AM
bmyles's Avatar
bmyles
I wouldn't trust a shop that would agree to resurfacing a dual mass. I've heard nothing else except that people get terrible vibrations after doing it. Sucks that the OEM clutch kit is so cheap, but the OEM flywheel is an arm and a leg. Could always get the Z1 or JWT complete kit. The clutches themselves are more than OEM, but the flywheels are way cheaper.
Old Jul 4, 2012 | 02:32 AM
Minor headache with the flywheel is that you have to inspect to see if it needs to be replaced. You have the engine-transmission apart. May as well do it then rather than later.
Dsowe
Feb 17, 2021 10:38 AM
dcains
Nov 11, 2015 11:36 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
QuintonC
Interior
Sep 9, 2015 12:10 PM
