What's wrong with my ABS system(No lights)
Old Jun 27, 2012 | 04:50 PM
rich2342's Avatar
rich2342
Default What's wrong with my ABS system(No lights)
Ok, I have read the threads about people's abs acting up. Each of them though throw Slip, VDC and ABS lights.. Mine does not.
When coming to a stop the abs will pulsate when it clearly shouldn't Nothing illuminates on the dash.. I tested the lights prior to start up and they are all functional.
I then tried an Abrupt stop from 60mph Abs did engage and worked under hard braking.
I don't know what this requires.. My rotors and Pads are in great shape and less than a year old and plenty of meat on pads..
How do I diagnose without throwing lights? Does anyone know what this is?
Old Jun 28, 2012 | 12:32 AM
JDMStanced's Avatar
JDMStanced
possibly loosened ABS line?
Old Jun 28, 2012 | 04:51 AM
rich2342's Avatar
rich2342
How do I check? Where is it located?
Old Jun 28, 2012 | 05:38 AM
Russ@Z1's Avatar
Russ@Z1
Do you have wheels and tires different from the original OEM specs?
What tread depth do you have on all your tires?
Old Jun 28, 2012 | 09:10 AM
350z006's Avatar
350z006
I had similar issues; mine was caused by my ABS sensor by the rear diff being misaligned with the axle flange after a pumpkin swap...
Old Jun 28, 2012 | 09:19 AM
TehkMob's Avatar
TehkMob
Yup, Id say its either a tire size issue and or a abs sensor out of place.
Does it act up when VDC is off?
IF IT DOESNT, then its mis sized tire/wheel setup.
if it does check the sensors. They are at each corner held on by a 12mm bolt. just look for a wire/plug. its the ONLY electronic thing in the front wheel wells and on the rear they are ousted to the diff housing facing the "gear" looking axle part.
Old Jun 28, 2012 | 10:26 AM
rich2342's Avatar
rich2342
This could be it, since my rear Diff mount is torn recently...
I jacked the car up last week and the sensor wires appeared to be intact.
Old Jun 29, 2012 | 08:26 AM
350z006's Avatar
350z006
Not just the wires...the abs sensors needs to be aligned with the little spokes on the axle flange...
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
