Please help confirm engine problem.
Old Jul 17, 2012 | 10:22 PM
2TH PWR's Avatar
2TH PWR
Default Please help confirm engine problem.
Before I attempt a resolution I just wanted to get the opinions on a problem I've been having.
Synopsis of facts.
2003 350Z.
- oil burning. Has been present and relatively light for a couple of years. But I never got a CEL and and it wasn't too big an issue so I just changed oil and really the car was a total garage queen.
the past year I started beating the car up at track days and I also installed some ART pipes. Blue smoke is now obtrusive. Brown oil coats my rear bumper. I go through 3-4 L in 1000 km of hard use. Smoke is worst at first start and at WOT, sometimes when pulling away from a stop.
I pulled my plugs for a 2 year change in March and they looked like this.
Hi, we are cyllinder 1, 2, 3, 5, 6. we are a little over 2 years old and we are kinda white and chalky.
I am cyllinder 4 and I am coated in oil and black crud,
I also noticed some brief hesitation occaisionally at WOT in 4th and 5th at the track, but it was sporadic.
I have also started getting misfire codes from cyl 4.
To keep my track days going I have been resorting to changing the oil everyday, and replacing the plug every day.
After one very extreme track event where speeds were very high (routinely over 120mph on a converted airport circuit cyl 4 spark plug looked like this. This is 2 track days and less than 1000kms.
So today I did a dry compression test. (did not pour a cap of oil into cyllinders)
Rear engine
Cyl 5 170 psi Cyl 6 172 psi
Cyl 3 156 psi Cyl 4 175 psi (Cyl 4 is the one with the black oil coated plug)
Cyl 1 140 psi Cyl 2 158 psi
Front engine
So the results of the compression test were super weird. I was hoping changine the valve seals would stop the oil getting into cyl 4 and causing detonation/ misfiring.
Anyways before I proceed experienced advice would be appreciated.
Side note, acceleration still feels strong for the most part.
This was my track video from Sunday July 15th.
Skip to 3:20 as everything before that is just me screwing around.
Old Jul 18, 2012 | 04:07 AM
2TH PWR's Avatar
2TH PWR
I forgot to add, those two shots of the cyl 4 plug were the worst two. (one 2 years old, and one after very heavy use)Typically if I change the plug after 1 track day at a less intense track the gap is not affected visually, although I do get the P0300 random misfire code. It's coated in a thin layer of black carbon, and it's also covered in oil on the inside. You can see the threads have oil in them too.
1 track day use. get misfire code at end of day.
Old Jul 18, 2012 | 07:57 AM
Lee R's Avatar
Lee R
#4 plug looks like a cylinder issue. Do a leak down test next to see the shape of your pistons because it looks like blowby past the piston and not your valve seals on that one.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
