broken bolt stud for the valve cover.
Old Jul 21, 2012 | 11:28 PM
JDMStanced's Avatar
JDMStanced
Default broken bolt stud for the valve cover.
i was installing the bolt that holds down the valve cover against the engine block, and the stud snapped off.. i know i'm not suppose to tighten them hard but i was just keep tightening until i felt like the gasket is sealed enough..lol
anyways, the piece of stud is inside the engine piece. i can see about one thread pitch (?) from looking down at it. and i can feel little bit of the stud from the opposite side.
how do i go about removing this stud?
oh also, instead of that bolt, could i use some other bolt for replacement?
thanks in advance.
Attached Thumbnails broken bolt stud for the valve cover.-img_2140.jpg   broken bolt stud for the valve cover.-img_2139.jpg
Old Jul 22, 2012 | 05:28 AM
ericjackson's Avatar
ericjackson
get a bolt remover kit. also, you probably over tightened the whole cover, i would remove it, check the service manual and get the proper tq specs and order that you are supposed to tighten. might as well buy a new gasket too. they are only like $18. oh. and youre gonna need a new bolt.
Old Jul 22, 2012 | 05:31 AM
taywan's Avatar
taywan
Think u cross threaded it maybe also or for sure over tightened only? Either way it may be a pain to remove.
Old Jul 22, 2012 | 05:33 AM
ericjackson
^ i snapped one on another block, cant remember how i did it. but when i got the bolt remover kit, it spun out without a hitch. it was not cross threaded. i still dont know how i managed to snap it
Old Jul 22, 2012 | 05:36 AM
ericjackson
Old Jul 22, 2012 | 08:03 AM
vtchang's Avatar
vtchang
Did the same on my FSDE, go to sears, pick up a tool known as the 'Grabit'
looks like
Go SLOW when you use the bit.
Old Jul 22, 2012 | 10:57 AM
JDMStanced's Avatar
JDMStanced
i hand tightened before using wrench so i dont know why itd be cross threaded..
those bits in the "grabite" looks pretty thick.. ill b afraid to use it cause it might mess up the threads around it..
Old Jul 22, 2012 | 12:35 PM
ericjackson
just get an extraction kit from lowes or homedepot. if youre like me, you'll use it again.. and get some decent drill bits to drill into it first.
Old Jul 22, 2012 | 07:38 PM
JDMStanced's Avatar
JDMStanced
thanks i got it out
Old Mar 23, 2016 | 04:59 PM
Bak3rme's Avatar
Bak3rme
thanks i got it out
what size extractor did u use to get out? im in same boat as u were whenever u made this post.
Old Mar 23, 2016 | 07:50 PM
HRMoneyPit's Avatar
HRMoneyPit
Do you people not look how old are thread is before bumping asking OP questions?
Old Mar 23, 2016 | 08:02 PM
Bak3rme's Avatar
Bak3rme
yes i did. i was hoping he subbed it and got a notification once i replied.
Old Mar 23, 2016 | 09:19 PM
nizmo_0385's Avatar
nizmo_0385
Dont worry the same people who bash for not searching and making new threads are the same asz hats who bash for bumping an old thread. Carry on.
Old Feb 1, 2018 | 12:51 PM
Moe Gwalla's Avatar
Moe Gwalla
thanks i got it out
did you have to remove valve cover and did you clean up metal shavings afterwards
Old Feb 1, 2018 | 12:56 PM
travlee's Avatar
travlee
Master
thread has been dead for almost 2 years, op hasnt logged in since then either
AbrasiveRaysive
Sep 20, 2021 02:29 PM
