Had code p0302 ses..now its..
Old Jul 22, 2012 | 08:01 PM
Zredman's Avatar
Zredman
Default Had code p0302 ses..now its..
It was misfiring, not just random
well I changed that spark plug, yes i only did the one so far because i wanted to test out if it would fix it. So i changed it, and now it's just all messed up, first time i started it, it died on me really quick. 2nd time it toke a bit longer but same result. but then all the lights everything from vdc lights to the slip one.
I have videos of it i will find a way to get them posted on here tonight. I think next thing i would change would be the coil?
**and never mind on the videos..some how i didnt record it other then it setting at idle normal for a few seconds
Old Jul 23, 2012 | 08:07 AM
Zredman's Avatar
Zredman
http://s63.photobucket.com/albums/h1...=VIDEO0011.mp4
couldnt get it to show up here as a video so heres the link 2 it, first start dies, 2nd it idles kinda rough and at a higher rpm then normal
Old Jul 23, 2012 | 11:20 AM
Neimad's Avatar
Neimad
See if any other codes popped up, feels like cam sensor.
Old Jul 23, 2012 | 11:38 AM
Zredman's Avatar
Zredman
should i drive it to get it the code read again? or try and get someone with a obd II reader?
Old Jul 23, 2012 | 11:40 AM
Neimad's Avatar
Neimad
Drive it for a block or two, search the forum for the trick to make the MIL flash the codes for you.
Old Jul 27, 2012 | 09:32 PM
Zredman's Avatar
Zredman
couldnt find that trick ur talking about, and i put it all back together, cleaned the TB and it worked fine...for about 2 blocks, then light came back on and sounded and felt like a misfire again.
Old Jul 29, 2012 | 10:04 PM
Zredman's Avatar
Zredman
so if wasnt the plugs?? what else would cause it to misfire?
Old Jul 30, 2012 | 12:01 AM
bender's Avatar
bender
Ignition coil
Old Jul 30, 2012 | 08:15 AM
Zredman's Avatar
Zredman
anyone know who makes the ignition coils? and as far as price goes, i know autozone sells them about 100 each, but im finding a few online for 40-60 range what are your thoughts on that?
http://www.discountbodyparts.com/cat...6061igco04ni35
http://www.partstrain.com/store/deta...78-8317103igco
and i mean i could always go get one from a junked 350z(dont think i would), but im not that poor this month so i dont have to do that
Old Jul 30, 2012 | 09:48 AM
bender's Avatar
bender
Hitachi makes the OEM coils.
Old Jul 30, 2012 | 10:34 AM
Neimad's Avatar
Neimad
Don't buy anything until your sure its the problem. Switch the coil to another cylinder and see if the code jumps. You didn't search hard enough, it's real easy search 350z check engine pedal flash:
http://www.nicoclub.com/archives/350...codes.htmledal flash:
Old Jul 30, 2012 | 11:05 AM
Zredman's Avatar
Zredman
Error 404 - Not Found
Sorry. The page you were looking for is not here.
this is what i got
Old Jul 30, 2012 | 11:07 AM
Neimad's Avatar
Neimad
http://www.nicoclub.com/archives/350z-ecu-codes.html
you need to learn the search function before you can fix cars
Old Jul 30, 2012 | 01:18 PM
bender's Avatar
bender
He's correct. Clear your check engine light, swap the coil in cylinder 2 with another. Wait for a code and your p0302 should change to p030(cylinder you swapped the coil with).
Old Jul 31, 2012 | 07:49 AM
Zredman's Avatar
Zredman
switched coils, problem followed but it showed 2 errors, both same cylinder but idk..http://sphotos-b.xx.fbcdn.net/hphoto...84287707_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...15391091_n.jpg
Old Jul 31, 2012 | 12:10 PM
Neimad's Avatar
Neimad
Code jumped to 304, 302 is gone?
Old Jul 31, 2012 | 02:40 PM
Zredman's Avatar
Zredman
Ya it jumped with the coil. But it gave me 2 p0304 codes in the pics
Old Jul 31, 2012 | 02:43 PM
Neimad's Avatar
Neimad
Thats odd but no big deal, you figured it out; change coil.
Old Aug 1, 2012 | 09:48 PM
Zredman's Avatar
Zredman
ok its almost all fixed up, but now its idle is all off, starts at around 1.5 rpm then slowly lowers its self to 500rpm. going to try and do the ecu reset stuff tomorrow and hope for the best.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
