350z Startup Issue
Old Jul 25, 2012 | 02:47 PM
CMDR Reservoir's Avatar
CMDR Reservoir
Default 350z Startup Issue
Hello my fellow 350z owners! About a month ago, I purchased my lovely 2003 Track Z, MT. It had 99,000 Miles on it but I have then since put 100,413 on it. About 2 weeks after buying my Z, I have had this startup issue. The following video I took will show you exactly what I have been experiencing.
I have tried searching the forums for this issue but I have been so far unsuccessful. Maybe I just suck at searching, but the video should explain everything. I'm not quite sure what brought about this issue. I should have shown the battery voltage meter but I assure you it's always within acceptable range. Right between 12 and 16. And yes, my foot was all the way depressed on the clutch and there is no rug or anything else blocking it. I appreciate any insight anybody can shed on this!
Old Jul 25, 2012 | 04:32 PM
JCITY's Avatar
JCITY
I'd guess the switching mech in your ignition key lock is faulty.
Have you tried to wiggle the steering wheel?Do you have another set of keys?
Possible the code off the key is malfunctioning?
Old Jul 25, 2012 | 05:42 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Checked the clutch disengage switch?
Old Jul 26, 2012 | 04:58 AM
laurentj23's Avatar
laurentj23
Have you tried jumpstarting it and see whether it works?
Old Jul 26, 2012 | 05:03 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yeah, that's a good idea if you can.
Old Aug 15, 2012 | 07:25 AM
nachospizza's Avatar
nachospizza
Wondering if you fix your problem yet? I think it is the NATS problem!!!! I am afraid I will face this problem one day too! I searched and it said it might be the NATS antenna problem! I want to know just replacing the Antenna without getting a new BCM and key fixed this problem???
416blueZ
Jun 11, 2024 10:56 AM
m_0g
Jun 3, 2021 10:05 AM
Ronso
Oct 30, 2015 12:39 PM
issyz
Sep 12, 2015 04:18 PM
Darkspy
Sep 7, 2015 09:09 PM
