Before i take a hammer to this car, please help me!
Old Aug 1, 2012 | 05:07 AM
SemaCondaZ03's Avatar
SemaCondaZ03
Default Before i take a hammer to this car, please help me!
ugh, well here it is.
I have been trying to replace my rear right side wheelbearing hub assembly for the past three days now, the axle nut WILL NOT BUDGE!! I got it to break loose and it turned maybe a turn and a half and then stopped, now it wont go either way, i have broken 3 craftsmen socket wrenches (thank god for LTW) I took a compact torch to it to heat it up, and just the sheer man power i have put into it but the thing WILL NOT BUDGE, I even went and got a compressor (not high impact so that didnt help.) NOTHING i do will make this thing budge, and i cant take the car to a shop because since it did turn twice the wheel wobbles now.
please give me some words of advice here guys, im really starting to run low on patience.
thanks in advance.
Old Aug 1, 2012 | 06:15 AM
PerfZ's Avatar
PerfZ
From the FSM:
1. Remove tire with power tool.
2. Remove cotter pin. Then remove lock nut from drive shaft.
3. Remove brake caliper with power tool. Hang it in a place where it will not interfere with work. Refer to BR-
38, "REAR DISC BRAKE (AD14VE TYPE)" , BR-44, "REAR DISC BRAKE (OPB13VB TYPE)" .
CAUTION:
 Avoid depressing brake pedal while brake caliper is removed.
4. Remove disc rotor and remove parking cable and parking brake shoe from back plate. Refer to PB-4,
"PARKING BRAKE CONTROL" , PB-5, "PARKING BRAKE SHOE" .
5. Remove fixing bolts and nuts in axle side of radius rod, front lower link with power tool.
6. Remove fixing bolt and nut in axle side of rear lower link with power tool. Then remove coil spring. Refer to
RSU-15, "REAR LOWER LINK & COIL SPRING" .
7. Remove fixing bolt and nut in axle side of shock absorber with power tool.
8. Using a puller (suitable tool), remove axle from drive shaft.
CAUTION:
 When removing axle, do not apply an excessive angle to drive shaft joint. Also be careful not to
excessively extend slide joint.
Standard value
Axial end play : 0.05 mm (0.002 in) or less
1. Drive shaft 2. Dust shield 3. Bushing
4. Axle 5. Back plate 6. Anchor block
7. Wheel bearing 8. Wheel hub 9. Cotter pin
SDIA1117E
WHEEL HUB
RAX-7
C
E
F
G
H
I
J
K
L
M
A
B
RAX
 Do not allow drive shaft to hang down without support for counter shaft, wheel joints, and other
parts.
9. Remove suspension arm and cotter pin at axle, then loosen mounting nut.
10. Use a ball joint remover (suitable tool) to remove suspension arm from axle. Be careful not to damage ball
joint boot.
CAUTION:
To prevent damage to threads and to prevent ball joint remover (suitable tool) from coming off,
and temporarily tighten mounting nut.
INSPECTION AFTER REMOVAL
Ball Joint Inspection
 Check for boot breakage, axial looseness, and torque of suspension arm ball joint. Refer to RSU-11,
"SUSPENSION ARM" .
INSTALLATION
 Refer to RAX-6, "Removal and Installation" for tightening torque. Tighten in the reverse order of removal.
CAUTION:
Refer to component parts location and do
Old Aug 1, 2012 | 10:54 AM
350zjason350z's Avatar
350zjason350z
Know it all
I just did this and I used an impact ...... Ratchets wouldn't work for me aswell
Old Aug 1, 2012 | 11:10 AM
Duckeee's Avatar
Duckeee
breaker bar and cheater bar(floor jack handle etc) pb plaster torch etc.
Old Aug 2, 2012 | 06:54 AM
05UltraYellow's Avatar
05UltraYellow
+1, add the occasional workout to weekly life, or steroids..
Old Aug 3, 2012 | 08:01 AM
SemaCondaZ03
**** THIS!
i took the car to a buddys shop, he took a brand new 800lb impact gun with a 250psi compressor, the thing DID NOT BUDGE, cutting the nut off after work today.
smdh at this car.
always wanted one, now that i have it, its nothing but a PIMA.
Old Aug 3, 2012 | 09:25 AM
lgear080's Avatar
lgear080
Feel ya bro. There have been very rough moments bt my car and
I, but the awesome parts always prevail. If you have to cut the
****er off and replace the assy.
Old Aug 3, 2012 | 09:27 AM
Duckeee's Avatar
Duckeee
i recently had a tough time with one of the cat bolts, but that stripped.
have you tried soaking it in pb blaster and torching it while using a big breaker bar and cheater bar?
an impact gun can only do so much. you're not going to get the action of one constant and strong leverage with an impact gun as you would with a bar. just saying.
good luck.
Old Aug 3, 2012 | 11:09 AM
SemaCondaZ03
we tried EVERYTHING you can possibly think of, my mechanic said the only thing left is to replace the axle, or try cutting off the bolt and hope we don't damage the threads and the axle too much and rethread it.
we've heated it up, used a breaker bar, cheater bar, broke 3 craftsmen socket wrenches, i mean everything you can possibly think of has been done,
wish me luck on cutting it off today guys (ima need it)
Old Aug 3, 2012 | 03:16 PM
Steve Lazarus's Avatar
Steve Lazarus
Good luck!!!!
Old Aug 6, 2012 | 07:31 AM
SemaCondaZ03
well, cutting the nut off was a fail, the mechanic said that before he even attempts to do that, i need to buy a new axle because chances are greater that he will fail and damage the threads on the axle, so he didnt even want to attempt it, i ordered a new axle and waiting on that to come in and get it swapped out.
jesus, mary n joseph i never thought one axle nut could bring so much stress and time consumption.
but hopefully the axle will be here within the next couple of days and the car will be back up and running, im sick of driving my sisters rogue lol
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
RWDBajan
Sep 17, 2015 04:52 PM
